All the big players really, Bosch, Dewalt, Milwaukee, Makita, etc. Really the biggest factor is how much you like each tool's ergonomics and how invested you are in a battery system.
they are still the only brand that offers brushless motors I believe
Now I'm all fired up on the Milwaukee FUEL Series,,,,,damn
9.6v on bad batteries literally was not cutting it.
And just think that's a solid 1/4 inch hex shaft that just got twisted into two pieces. I've watched videos of how fast the 12v vs 14 and 18 v impacts were, and it seems like the speed/ amount of strain on the fasteners goes up way faster than the maximum torque value might imply. In that sense I'm happy to see brushless is making multi-speed impacts easier to implement, since it's just a command to the motor's ESC and not a mechanical transmission. I'd say 1500 inch lbs is almost too much power for a 1/4 inch bit unless you're only using it for extra speed with those huge decking screws into wood.
So, do we really need 1500 in/lbs? If you need that much torque, you are likely working with very large nuts and bolts, so much so that you probably wont be able to take advantage of the full twisting power without breaking your wrist with one of these little impact drivers!
Wow - nostalgic to say the least, but it still looks pretty modern compared to the one of my dad's that I used to use all the time!
The new 12v lithiums have nearly the power of NiCad 18's, in some cases more (drill -> impact). For light to medium jobs, its all that you need.
I've been using the Milwaukee M12 lineup for a couple years now and it was the torque that convinced me that they hadn't gone over to making toys for the homeowner. Great torque, smooth keyless chuck that doesn't tear up your hand and built in reserve meter so you can quickly determine whether or not to recharge.Check out the Milwaukee cordless offerings now, they are still the only brand that offers brushless motors I believe, and they are about the most powerful as far as torque is concerned as well. Milwaukee has been around a LONG time, and they make fantastic tools.
Ahh, that's one of the nice things about Impacts, there's little to no torque feedback to the user, only a mild pulsing sensation at most. I get way less wrist torquing than I do from a little 80 inch/lb pocket screwdriver, and compared to a 600 in/lb 18v hammerdrill it's less than pulling the trigger with an empty chuck.
Nope - you don't know what's happening there because you forgot to watch the whole video and placed your presumptive reasoning in the place of observation and practical logic.just saw the video above..heh, I know whats happening there: the screw got hot from the first in and out! On the third insertion it started melting the resins in the wood, then when it stopped, the resins started to cool, and it was heck to withdraw..
I see this is the same video that EG posted on the previous page, didn't see him edit that one.
I don't want to give the idea that it's superior to a drill in every way
Is there an impact driver that has the option of shutting off the impacts for use as a drill or driver for smaller screws?
