Nope - you don't know what's happening there because you forgot to watch the whole video and placed your presumptive reasoning in the place of observation and practical logic.
The impact driver was able to withdraw the screw immediately following the non-impact driver twisting the piece of wood around, not to mention the users wrist. What's happening there is the difference between straight torque and the way an impact driver works.
Yes, there are some newer models that have this function. Makita and Bosch have one, I'm not sure about others. I'm unsure how practical it is exactly since you're always going to have more runout with an impact's hex chuck. With smaller screws feathering the triggers (which are pretty nice these days) is usually a better option. Drilling smaller holes with an impact only usually doesn't cause problems, since a sharp drill bit doesn't provide enough resistance for the impact mode to kick in most of the time. The only issue is finding a high quality hex-shaft drill bit that's long enough. The impact rated ones from dewalt work well though they're rather short, but if you just need a hole in a 2x and don't need it to look perfect a normal impact driver works fine.
Snapon's lithium... yes- they are expensive. yes they probably aren't needed for normal use that most people need. BUT- when efficiency equals profits made, tools have no price on the cost of business.
Hilti is making very reliable, professional machines and became the synonym for hammer drills in Germany, Austria and Switzerland.
My desire and concern about the ability to switch off the impacts on an impact driver was more because of experiences I've have when trying to remove or install a small machine screw or any type of screw for that matter, with a slot or Phillips bit with the impact kicking in and causing the bit to constantly slip off the screw.
If you go read both of our posts again you'll see that you jumped to the wrong conclusion and I simply corrected it.No, whats happening here is youre alienating me with your obnoxious attitude and insubstantial posts..
Looks pretty neat and I suppose if you're already using a bit holder this could take its place while adding to the life of your bits too. Do you already have one of these?The DEWALT DWHJHLD Impact Clutch Tip Holder has an internal clutch mechanism that delivers 5X longer bit Life. It has a robust shank for use in an Impact Driver or Screw Gun. It has an on and off switch that allows the user to determine torque delivered to work piece. Turn ON to minimize bit stripping, bit breaking and screw stripping, turn OFF to fully utilize the torque of your impact driver or screw gun. $10 bucks. at the 'zon.
These look great. As you point out, price is only one part of value. Do we know if they make these?
LOL! "Dutch rudder". Awesome handle brother!!:laughing:
These look great. As you point out, price is only one part of value. Do we know if they make these themselves?
Sounds like a plan.
In the US market, the US brands show everything they have. Makita seems to have only a fraction of their total catalog. Not sure about Bosch. A perspective on the broader EU market would be awesome. It looks like some of the US brands are there, but presumably as also rans.
Screws are the whole point of impacts. The back and forth of the action is supposed to enhance grip on the screw, reducing spin outs and stripping. Maybe its an early model or a weird design?
The little guns are made in (gulp) china, but the big guns (3/8 and 1/2) are built in the US.
And i think that also buying habits have a big impact on market shares in the respective markets too. What "Buy US" is in USA is "Buy German" at this end here, not only for powered tools but also for other machinery and hand tools.
start naming names! I didnt think they were that light either ie. 3 lbs or under..
But if it's good enough then the warranty won't matter! I'm sure no one would offer a Till the End of Time warranty, although it would be cool if they did!no, it says lifetime. that means one, doesnt it?
