Been having a problem with my CR123s self-discharging in my SF M6.
Incident 1: A few months ago, I used the M6-MN20 for about 30 minutes spread out over about 4 or 5 on/off cycles. After that, I twisted off the light. I also added an extra 1/4 revolution twist in the off-direction to ensure the tailcap isn't in an intermittent off-on position. Then I put it back on the shelf next to my bed.
A few weeks after that, the light wouldn't switch on and the batteries were dead. I was puzzled and thought that maybe the cells were already partially dischaged when I previously used it. However, if this was the case, then the M6-MN20 would have looked quite orange and dim towards the end of usage. I did not remember noticing this and so I suspected something was wrong with the tailcap. I emptied the M6 and left it battery-less, deciding to return to it another day when I have more time to investigate. For the time being, I would have to settle with my other lights...
Incident 2: A week ago, I found some time and picked up the M6 again. I put in a new batch of Sanyos measuring about 3.25 v. Then did the 30 second test and switched the light off and added the usual 1/4 revolution to keep it off. I then left the M6 alone for four or five days and yesterday, I took the batteries out and they measured 3.02 v. That's low! A 3.02 v reading would usually be associated with a half-discharged M6, not one which has run only 30 seconds! :shakehead
Has anyone had a similar incident in the past or know someone who has? is this a problem with the tailcap? Tried researching CPF but couldn't find a precedent tailcap problem, at least not with this newer version of the M6.
