Quick ?/help with My Inova X-1
angelofwar
South Carolina
O.K., reason just went out the window...I put an energzer lithium AA (measuring 1.53 volts), and a Rayovac Alk. AA (measuring 1.34 volts) in my X-1. The Lithium should have given it higher out-put than the rayovac, right? Nope..the light was noticeably brighter with the rayovac than with the Ener. Lith.. Can batteries just have bad Ju-Ju, and not run the light as bright, or am I missing something? Somebody please explain it to me!!!:hairpull:
I thought the X1 was semi-regulated, so the outputs should be about the same, not sure why it would be lower with the lithium though.
Lithium batteries contain a PTC protection device to protect against short circuiting the battery. This PTC device has a low initial resistance that rises rapidly once it reaches it's trip temperature range due to high current. When the PTC cools, the resistance drops back down to a slightly higher initial value than before it tripped. Multiple trips will increase the initial resistance to the point where the PTC limits maximum current to an abnormally low value.
When this occurs, a digital volt meter will still show a good battery based on voltage; however, a battery tester, which measures voltage under load, will indicate a bad battery.
How can this happen?
1) The battery can be overloaded by a short circuit or excessive load which will cause the PTC to cycle until the load is removed.
2) The battery can be exposed to external thermal cycling, i.e. a battery in a black flashlight on a car's dashboard in the sun. Thus the battery is cycled once per day.
Hope this helps.
Bruce
Thanks for the responses guys...especially Old BJC. Yeah, I just put the same lithium in my "New...LOL" River Rock 1-Watt AA...and nothing...I'll definitely keep the old lithium's away from my duty lights and bug-out bag...I mostly keep lith's in my SL Sidewinder...but once they no longer run that, I'll trash 'em. Again, thanks for the help everybody
