EDIT: based on input from other CPF-ers and the fact that i posted this the day a got it, i want to be very clear that this is a very initial view, it hasnt been used for long yet. CHeers
Was wondering what the R5s were like so ordered this R5 drop in drom DX just to give it a try.
It arrived yesterday and it was surprisingly nice, the reflector is made of metal not plastic as i was expecting and screws on and off the LED pill/heatsink which also feels quite nice. There is some epoxy/thermal paste around the LED itself but it doesnt touch the dome nor does it affect the profile of the beam.
I got the single mode as i am figuring on using this only when more light is needed, it will be riding in my G2 running on 2xRCR123s and my K106 3 mode programmable on 14500 is the primary EDC with the Raw NS (20/100) bein the back up.
Beam profile, a larger hotspot than i am used to, comparison pics taken below using my Jet III Pro ST on max. Have not done any runtime tests yet but will get around to it sometime.
Suffice it to say, this one BRIGHT dropin for a sub $15 item. They have a 5 mode too, but i didnt need that as my other lights serve that need already.
Below: Pic of the drop in, sticker says "Super Bright R5"
Below: Closer pic of the LED
Below: Side view with both springs
Below: Side view, spring removed to fit in G2
(note: the other P60 hosts needed the larger spring)
Below: R5 drop in, reflector removed
Below: side view of drop in without reflector
Below: as close as i could get of the LED, note some thermal paste/epoxy spillover
Below: R5 dropin fitted into Surefire G2, no rattles at all
Below: beamshot of R5 drop in, about 6ft from the wall, loads of ambient light as it is noon here.
Below: beamshot Jet III Pro ST Q5 on max (note the hotspot is so muh smaller)
Below: comparison: R5 on left, Jet III Q5 on right
Below: comparison as above just that i moved the lights further apart
I like this dropin, i only wanted a single mode as (a) less things to mess up, (b) only needed a single mode for my uses.
TINTWISE: As you can see from the shots, the Jet III appears a bit but just a bit warmer, the beam profile and tint of Jet III is very nice, slightly vanilla-ish. The R5 on the other hand is a blindin white, would be great for indoors to light up rooms, search all corners etc. But will be takin this R5 outdoors with me as well to test out.
EDIT:just tested the drop in on my other P60 host running a Trustfire Protected 18650, it appears to be just as bright to my eye.
