Now, I am wondering: How long do these lightbulbs actually last. Let's say till 80% light output. Are there any real tests that could confirm the claimed several 10'000 h life-span. Does anybody of you did some testing?
I'm in the process of both lumens testing and long-term testing LED lamps for someone. When I get the OK from him, I'll start a thread. The 2 ones I long-term tested which used 5mm LEDs faded to under 70% in 300 hours. The rest using 5mm I deemed not even worthy of long-term testing. Most had outputs not much more than night-light bulbs.
I'm testing 6 lamps with power LEDs long term right now. So far 3 of the 6 are actually above initial output at 300 hours, one is at 98%, the other two are around 95% and 87%. They hit the 1000 hour mark on November 29. Results should be interesting.
I just looked at a few high powered light bulb here in a store. The 3 x 3W LED bulb was on display. It was quite hot - still able to touch the casing of the bulb though. So, I am guessing that the dies get substantially hotter...
That's the problem right there. Based on my testing, the light bulb form factor is incapable of dissipating more than about 5 watts using passive cooling, period. In fact, I'm really more comfortable keeping the dissipation below 3 watts. Anyone who makes a lamp which dissipates more than that without active cooling is making garbage which won't last. Unfortunately, this simple little fact is going to limit LED screw-in lamp replacements until LEDs become somewhat more efficient. Either they won't last, or they won't have much output, or they'll need active cooling (which will add to the price).
if it is getting uncomfortably hot I wouldn't say it would last more than 6 months to a year without fading to 50% IMO. personally unless I had something that really needed an LED light bulb I would not buy them at this time they are way too expensive to be cost effective at this time... perhaps in a few years if the environmentalists get things fouled up where electricity prices go way up then the market will take off.
No, decent LED bulbs aren't going to get that much less expensive than they are right now. I'm figuring retail about $40 to $50 for a decent lamp with good electronics, 100K hour life, and active cooling (which is needed to reach outputs rivaling 100 to 200 watt incandescents). These prices may drop by perhaps $10 with mass production, perhaps even more if emitters get so efficient that no active cooling is needed, but you'll never see decent LED bulbs for the same prices as today's CFLs. If you do, then it means it's junk which won't last, same as the problematic $2 or $3 CFLs we already have. So you can have cheap or good, but not both. We've seen the same thing with CFLs. The $2 ones, or even $6 ones, are often a crap-shoot with regards to quality. Only once you hit the $15 or $20 price point are you fairly sure of getting a decent lamp with a guarantee the manufacturer will back.
Honestly, for what it might cost to put a few decent LED bulbs in an existing fixture, we can more cheaply engineer a brand new LED-specific fixture which will cost less. This is why I think long-term LED bulbs will be a passing fad. Consumers will balk at the price compared to purpose-built LED fixtures, and will just go with the latter.
