Hello 3000K,
The HO-9 from LumensFactory is a D26 style lamp module and will work in just about any light that accepts a "P60" type lamp.
IMR16340s are not protected, however, this should not be considered a negative.
The reason regular LiCo cells need to be protected is for safety reasons. When Lithium Cobalt chemistry cells "go-off" (combustion) they produce their own oxygen during the burn, which accelerates it, while at the same time, produce harmful toxic excrement, (hydrofluoric acid in gas and liquid form as I understand). The odds of having this happen are pretty low, but are exponentially increased when the cell is repeatedly abused. (over-discharged, over-charged, or drained too quickly). The protection circuit in your 3.0V (buck regulated LiCo cells) are preventing you from using the P61 as a safety precaution. The P61 would be at least a 4C load or higher on the cells, and the voltage-bucking diode would generate major heat at these discharge levels, which would be further cause for concern.
LiMn and LiFePO4 chemistry cells are often categorized as "safe lithium" chemistry cells. They can handle much more abuse (in the form of fast discharge rates and over-charge/discharge) than ordinary Lithium Cobalt chemistry cells before venting. When they do "go-off," they do not produce their own oxygen to fuel the burn and produce far fewer toxic excrement.
Fast discharging and fast charging and over-charge and over-discharge are all going to reduce the useful cycle life of a LiMn cell, but it is very rare (pushing non-existent) to experience a catastrophic failure with LiMn chemistry cells when used within reasonable perameters. They can be thought of as ALMOST as safe as a NIMH cell (NIMH cells are NEVER protected).
With all of this in mind. The need for a protection circuit is drastically reduced. A protection circuit adds resistance, which will reduce performance in direct drive applications (most incans). A protection circuit is also just another failure point. If the circuit fails, it can render a cell useless very suddenly. By eliminating the circuit on IMR cells, we are actually improving overall reliability.
-Eric
Is the HO-9 another p60 dropin and are the IMR16340 cells protected? The current 3.0V Tenergy cells that I now have are protected and wont even light up the p61.
