Looking for an 18650 EDC light that can also be mounted to my .308 Win (7.62x51 NATO) rifle as needed.
==================Flashlight Recommendation Checklist================
This will be mail-order or Online (location doesn't matter).
2) Budget
Up to $100 preferably, but can go up to $150.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
4-6 inches - Every day carry.
5) Emitter/Light source:
Neutral White LED - CREE XP-L most preferable
6) Manufacturer:
I want to buy a light from a good quality manufacturer that is ready to go out of the box.
Orbtronic 10A 3500mAh dual-protection 18650 Diameter (mm): 18.6 mm (+/- 0.03) Height (mm): 68.9 mm (+/- 0.03)
8) How much genuine out the front (OTF) light do you want/need?
I want search and rescue type illumination (800+ lumens) preferably without automatic stepdown.
Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
5 to 100+ yards typically, but up to 200 yards (not a deal breaker) useful in some situations.
As long as possible from a quality 3500mAh battery...
Very Important (Camping, Backpacking, Car Glove-box).
Critical (Police, Fire, Search & Rescue, Caving, Survival).
I want a tail mounted switch
I want 4 or more non-blinking light levels
I want a strobe mode.
I want a beacon mode. Regular flashes at full and/or reduced power to show location - flash rate somewhere between 2 & 5 seconds per flash preferable
I would like SOS mode. (blinks in . . . - - - . . . emergency pattern - preferably at max power)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III HA
Stainless steel (durable, but much heavier than aluminum)
Color doesn't matter, I will Cerakote the flashlight at some point down the road to match the rifle.
15) Water resistance
IPX7 or better
16) Storage conditions
Daily use stored in house, but may also find itself in a backpack, glove box, or weapon mounted from time to time for up to a week at a time.
0.80" - 1.00" (20mm - 25.4mm) body diameter for weapon mount.
maximum empty weight 4.25 ounces.
maximum head diameter 40mm
NO PROPRIETARY BATTERY.
2) Budget
3) Format:
4) Size:
6) Manufacturer:
IPX7 or better
