whitenoise
So I've been looking around the threads getting information about dive lights. As mentioned by linger the more I read, the more an off-the-shelf recommendation is no longer for me. Since you guys are the extremely intelligent ones :bow: I've decided to ask if anyone could make me a custom dive light?
First up, I'm after a hand-held light rather than a can light. This is because I want to be able to take the light on holiday, and I'm not a techie diver so can lights, umbilicals, Goodman handles etc are all over my head. My diving will only be recreational single-tank diving up to the 35m range, but will be dives in the UK (low vis), but also in blue water (Mediterranean, Red sea, Caribbean etc). So this type of diving will be a mixture of wrecks, wall dives, reefs, general topography, swim-throughs, caverns (not caves) low vis, quite varied really.
I've been looking at packhorses W200 mods (they look good) and wquiles super-bright barbo light which look great! I don't have the budget to go for custom machined hosts, so its probably going to have to be a mode an existing host, which makes me think of the W200 and the barbo hosts etc.
Now this type of varied diving is where my lack of knowledge might come in play. I'm not after a tight tight "pencil" beam since I actually want to light up what I am looking at! Consequently I think a really intense hotspot without any spill might be too "intense". I'm not a professional photographer (or any type!) so a massive flood is not needed, but a decent enough spill/flood (sorry if I'm not using the right terms) would be great. I don't need lots of throw, since generally I'm going to be within a meter or two of what I am looking at anyway. I can't really say a "degree" of what I'm after, as honestly I couldn't say!
In terms of brightness, I'm after a bright light. I don't know much about the technical terms (emitters/bin/die) etc, but I've been reading around and it seems that R2, MC-E M-bin and P7 leds are the ones being talked about as the brightest ones at the moment. Now these could be all the same led, or just different types so you will have to excuse my lack of knowledge here! Looking at wquiles thread about the modified 3x MC-E M-bin light was just awesome - but I've no idea on cost, practically etc.
A couple of light "stages" would be good, say 100%, 50%, 30% something like that? This way the light could be dimmed down on night dives, rather turning a night into a day dive! I did think about a 10% mode or something for emergencies on the surface, but I like the idea of a post I saw here somewhere. It said about using Javier's battery canister with some backup batteries inside, so if you needed the torch for signalling on the surface, you knew you had a backup. Not sure if this practical though, depending on battery size.
I've no idea if any of this has made any sense(!), or if this is possible, it's completely up to you guys to recommend something, and then for some-one to build it! This might be completely wrong, but Packhorse did mention something about 2 R2's and 2 MCE's, switchable between the two? Would this give a narrow beam when the R2's where on and a wider beam when the MCE's where on? Ideally a focusable light would be great, but I see from Javier's posts about the U-04 and U-15 we are not quite there yet.
Anyways, over to you
