Brian321
For RCR123's and AA's? Im looking for a decent brand at a resonable price. Thanks.
Well i found this one but its only for AA's or AAA's.ditto I'd like to know too...just to warn you, when I did my own research some time ago, all I could find were ones that would take days to charge (portable size ones at least I"m assuming..)
As long as your budget approaches that of the DoD, PowerFilm Inc. can provide you with an extensive line of truly serious solar-power products:
http://www.powerfilmsolar.com/
They're even the OEM of the fold-able charger you linked in post 2:
http://www.powerfilmsolar.com/... foldable-products/
If you're just trying to make a solar charger for lithiums and NIMH cells, you can skip the 120VAC inverter Kilted recommended. Assuming your existing battery charger runs off a wall wart, most of those output some DC level which drives the actual charger. My Pila IBC takes 6V @ 2A and my MAHA C9000 12V @ 2A. You can get the 12V directly from the 12V 18AH battery that the solar panel charges, and use a resistor to get 6V if you need it (or use two 6V batteries that you can connect in series or parallel if you want to be more efficient).
You just need to watch the meter can do 1 cell lipo. Most don't.
Heres the model I have, from this seller
http://cgi.ebay.co.uk/Mini-Lipo-spa...ViewItemQQptZRC_Modellbau?hash=item3a590711c6
