removing an epoxied emitter
Lolaralph
Pennsylvania, USA
my first mod has run into some problems, i think i used too small gauge of wire to connect everything, switch to h6flex and driver to SST50. i'm trying to get 5 amps to the emitter and i used 24 gauge teflon wire. My question is, can i safley remove the artic alumina epoxied emitter from the britelumens heatsink so i can use the heavier wire without destroying something, the epoxy is about a week old
It is going to be tough to remove it from that heatsink. You need to heat up the heatsink to soften the epoxy, then carefully pry it up. I have snapped leds in half with very "minute" force :shakehead it was an SST50 in fact. For 5 amps you need thicker wire I would say. And to fit that wire in the BL heatsink you will need to or should open up the area the wires pass through. There is not enough room in the stock BL heatsink for 20 gauge wire, and that is what I would recommend. If you dont feel good about modifying the heatsink just use the biggest you can, which might be 24 :(
It takes A LOT of heat to soften cured epoxy. I recently removed a bunch of epoxy that was half glow poweder from one of my lights and even with direct contact to a 30W iron, it was very slow going. Even if you could get the heatsink hot enough, odds are the emitter might not survive. You have your own personal safety and skill level to consider too.
If it were me, and I had decided that maintaining the heatsink's original design was worth possibly sacrificing the emitter, then I'd put the heatsink in a vise and heat it with a plumber's torch, then pry up underneath the emitter with a jewler's screwdriver. After the emitter is off, I'd have to carefully remove all the epoxy left behind while trying not to damage the andozing which is necessary for electrical isolation where the emitter contacts or wires might touch the heatsink directly through the epoxy. I'd probably use the tip of my 30W iron for that part.
If I had decided that the emitter is more important than the heatsink, then I'd try to double up on the wires without removing the emitter from the heatsink by drilling new holes through the heatsink for the additional wires. With careful, deliberate work with a dremel, I'd have to remove any heatsink metal and wire insulation in the way to gain access to enough copper strand right near the emitter base to solder onto. Once the copper is exposed, I'd epoxy around it to insulate the new joint from the heatsink before soldering the new wires onto the old.
Honestly, I probably wouldn't bother with either option. They both have a very low chance of success.
I think you have one realistic option here.
What's done is done. Leave this one as is rather than risk destroying some pretty expensive parts. If it really bothers you, then build another one first. If you find that a direct comparison reveals such a difference that warrants risking destruction of the first one, then go back and try to remedy this one with one of the two options above. If your remedy fails, at least you haven't destroyed your only working version.
Oh and one more thing...
Before you do anything else, beg borrow or steal a clamp meter and clamp around one of the wires going to (or from) the emitter to see what kind of current you're delivering. If it's 4.2A or more, then don't bother doing a thing! In my experience, the visible difference between 4.2-4.5A is negligible and between 4.5-5.0A the SST-50 creates more heat, but not more lumens.
