@ Wutda
Wife eye rolling... I know the feeling man! Just remind her that addictions come in much worse forms than flashlights, and she should be lucky if flashlights is your addiction
I love this light. I used to have a flourescent lantern to take camping. If I rolled into a campsite at dark and had to have some light to start unpacking I could use the flourescent first then once the propane lantern and bottles were unpacked switch to those. But this little guy is lighter and takes less room, is easier to have sitting right on the top of everything else ready to use immediately, looks as bright as my flourescent (althought the output isn't as even... gotta try that Press N' Seal idea), won't burn out and make me look all over the place for a replacement bulb, won't give fits starting in cold weather, and uses cheap rechargeable or Alkaline AA's!
If you use it in a corner or edge of an area, you can wrap aluminum foil (shiny side facing the LED of course) around half the lantern and get a little more brightness towards the other direction. Helps fill in the gaps a little too!
