allburger
Well, I built an ROP about 3 weeks ago and I used a 2D maglite, KAI 3aa/1D adapters, Kai MOP reflector, Kai glass, Pelican bulbs, and Rayovan 2500mah nimh's.
The light was fairly bright, but i still wasn't satisfied. I knew that since I was on a budget and forced to use the Kai battery adapters, it was eating up quite a bit of power due to the resistance in the springs.
I also picked up some thin copper sheeting commonly used for crafts at Michaels.
I used my multimeter and found that the problem wasn't in the tin, but rather between the tin and the springs.
So what i did was take the copper and use it to help connect all the springs to the metal on these things. Probably tin.
This is the battery pack with eneloops and the copper resistance fix
Rop High Bulb
Rop Low Bulb
The advantage to the eneloops with the copper fix is a much brighter light. I put the old batteries back in there with the copper fix and much to my surprise it was also very bright. I gave the eneloops a lot of credit for making it brighter but I believe that it was the copper that helped the most.
I hope I helped someone here who is currently running the Kai adapters.
Rop High Bulb
Rop Low Bulb
