Onuris
I seem to recall a similar situation back in the late 80's or early 90's, it was either with Audi or Volvo, can't remember which. Ended up being a few instances of operator error from what I remember.
I, too, have a dumb question... Why don/t they make the brakes on vehicles more like the air brakes on big rigs, as in, you release air pressure by stepping on the brakes, and the loss of air pressure causes the brakes to apply?
I do however, realize what a cost this would be to automobile manufacturers, with additional r+d manifested in higher prices, but then you couldn't have brake failure.
I have a really dumb question, but if I had a "runaway car" couldn't you put it in neutral (or manual transmission out of gear)? Then it seems the brakes should stop it even if the engine is running to beat the band.
Because English phonics, irregular as they are, fairly regularly change the sound of "c" when it is followed by "e" or "i". When you add "ed" to "panic" regular English phonics would want that to sound like "panised" -- probably not what you wanted to say. To prevent this incorrect pronunciation the convention is to add "k" (or in the case of "picnic" to just change the final "c" to a "k"). That's what happens when a language borrows bits from half the other languages on the planet.On a separate note, why the hell do you have to add a letter "k" when using adjective form of panic?
I don't see where speed or high braking effort leads to boiling brake fluid. The pressure of the panic stop would greatly reduce any fluid's ability to boil. What am I missing? :shrug:Accumulated speed combined with powerful engines equals boiling brake fluid and no brakes.
I like math! Thanks for bringing a little objective science to the discussion. I also agree with your conclusion. :thumbsup:You may be correct here. I was just doing some math.
Agreed on all points!Yes, I now tend to believe they just gave up, perhaps because the brakes weren't as effective due to the combination of conditions. Nevertheless, this is still a dangerous problem meriting correction. If a 19 year CHP veteran has trouble controlling a vehicle, you can bet the average driver will be utterly helpless.
I don't remember the source of that quote, but my guess is it was a news reporter. We need to remember that news is entertainment selling advertising time. The more sensational the report, the more eyeballs the station can sell to advertisers. :thumbsdow They want us to believe they know what they're saying...I don't understand why the brakes of the Lexus would be "on fire."
As has been stated by at least two others, this is a supremely logical idea. The only potential fly in the ointment is whether the Prius' (or this Lexus') electric motor goes through the transmission or is more directly coupled to the drive axle. Some purely electric cars have the drive motors mounted on each wheel. This seems awkward (at best) for a hybrid. Does anyone know how these hybrid drivetrains work?I have a really dumb question, but if I had a "runaway car" couldn't you put it in neutral (or manual transmission out of gear)? Then it seems the brakes should stop it even if the engine is running to beat the band.
Ctrl-Alt-Del
i have 2 cars with drive by wire, never had a problem.
there is also such thing in all cars, as emergency brake, the trick is to apply it gradually, or you'll spin out of control.
e brakes are mechanical, and any electronic or engine failure doesn't affect them
I don't see where speed or high braking effort leads to boiling brake fluid. The pressure of the panic stop would greatly reduce any fluid's ability to boil. What am I missing?...
The e-brake uses the same pads/rotors are the normal brakes. If normal brakes are overheated, then the e-brake does not work either. Most e-brakes don't have the same stopping power as normal brakes either.
Some Subarus had/have the parking brake connected to the front.
You're missing that prolonged braking from a high rate of speed leads to a massive amount of heat produced. It has to go somewhere, and will eventually overheat the brake fluid.
Wait a second, why doesn't the driver just jettison the warp nacelles? That should stop the vehicle.
The newer models abandoned the flaky hyperdrive, plus as Star Wars fans, they are unable to understand the more practical Star Trek technology.
