Where did THIS come from?
Never said anything about different battery sizes. I figured in a flashlight that you can run 3XCR123's, you can only FIT 2X18500's because of the LENGTH of the tube.
The reference to the Pila light I took as the drop in was also compatible with that light, which is a 4XCR123 or 2X18650's.
Different form factor. But the STATED runtime from LF is for the 3XCR123 FORM FACTOR. No?
You still don't get it?
LF states runtime on certain types of cells:
Runtime (CR123A): ~40 min
Runtime (3.7V Rechargeable): ~60 min
3 x CR123 cells, which are primary Lithium cells, are a specified standard type of cells in size.
They also says runtime on 3.7V Rechargeable, which they have specified here:
"Pila®
GL4 Rechargeable (2 x 600P)"
Pila 600P cells is a type of cells supplied from a vendor, for certain lights.
These are, as described in the post from AW:
"Size Reference :
18650 = 168A / 600P"
in which AW describes which cells he can supply to replace the Pila 600P cells.
Nowhere but in your mind is there a connection between the size of 3 x CR123 cells or 2 x 18650 cells!
Please read the post from AW!
LF does not state anything about what light these drop-ins go into, only the runtime on specified type of cells.
And this does not anywhere state that 3 x CR123 equals 2 x 18650 in size!
