I bought a number of these a few years ago and still have 2 brand new in the blister pack. Great deal at the time. Well....I have been trrying to learn and become as little more knowledgeable about flashlights. All of the abbreviation's are a bit overwhelming though. :thinking:
I did a search in the hopes of learning how to convert these to LED's. There is not much information and most of the threads are 2 years old. I did recently see a thread topped about a battery exploding in one of these but nothing more recent.
2 more years of technology and LED dropins fairly common now. Is there something out there that will work as a drop in? I did find this message and picture in the archives from Nikon about the size at the time.
I looked around for a drop in that might fit the size. There are a few over a DX and Kai. The diameter is not so much an issue as the length. If I was to find one that fit or even mod the springs a bit, will it work? Or do I have to concern myself with the electrical aspects? I see a lot of talk about voltages, amps etc. I know next to nothing about these. I assume (bad I know :naughty that if I can make it fit it will likely work. The light uses CR123's now and the voltages should work if I understand the little I have read here.
If this is the wrong forum to ask, Mods please move to the appropriate one.
Thanks in advance.
What does fit absolutely perfectly, however, is the lamp assembly from a UK 4AA, both the eLED and the incan type. With the incan you can use either the 2w. or 4w. version.
Thanks in advance.
