ergotelis
Hello, I used my IR thermometer to measure some temps directly into the core of the led,distance 2 cm.The IR thermometer is accurate, proven by tests with different ways. after running a seoul P4 at ~800mA and ~3,5V, i measured after 10 minutes 70 C on core . Is this considered a safe temperature?Or should i improve heatsinking?Thanks!Generally, which are the limits of a Seoul led?I tried some search, i found some info mentioning that the limit is 125 C. Is this accurate?
