Hi fella's,
I'm sorry this has all got confusing about what I want to do but with your help i'm progressing well.
Ideally I wanted 3 d's running the torch but had initial problems with low amps. I seemed to have reached a point where my cells provide 2.3A tailcap measured with pointy ended leads. Seeing as the driver is 2.5A not a bad outcome.
I had read that this driver can also put out 2.8A with replacement thicker gauge wire over standard but I misunderstood and thought this was again with 3 d cells.
Hence a lot of my frustration.
Some advice from you guys got me trying 4 c's as I had these at home.
Using these I got about 2.8A but this fell of rapidly to 0.7A so I thought this was a cell problem or a faulty board.
Advice from you guys again got me burning my fingers which confirmed a theory that the board was cooking.
So out came some very ugly heat sinks just held on with tape and this slowed the current drop.
Tonight, out came the iron again and using Justin Case's suggestion I made some stand offs from 16awg wire soldered to the mounting tabs then filed flat to mate with the sinks.
Using compound the torch held it's current for as long as I could hold the pointy ends of the dmm on the torch, can't believe the difference!
I've now cleaned this off and am in the process of waiting for the thermal epoxy to go off so I can give it a full run time test and let you all know the results.
Besides it can't hurt to have the driver heatsinked anyway can it.
As I mentioned earlier somewhere in the post (it's been that long) I've done a basic version of the spring resistance mod and I also ran a wire from the +ve spring tip through to the switch to improve that.
I had been cleaning the contacts as best as I could remember with IPA before soldering etc. I don't have any of the deoxit stuff.
Mettee, I'm sorry for missing you out. The output is fab at 2.3A but I seem to have got caught up in the 2.8A mission even though the driver is 2.5A - guess this is the start of something expensive
I hope I answered everyones questions and I think I'm reaching a happy place to stop.
Now how do I get a tighter beam out of it
Cheers
Jez
