I really appreciate all your efforts with this.
Was 2.3A about right for direct drive?
The torch is at work right now and I can't get to it till Sunday but getting this list of things to try is promising.
I soldered the led using both the legs with the wire laying across them as it was easier this way without a third pair of hands. Will that make a difference?
How is the front of the board connected to the back? Could one half of the boards regulators not be connected somehow?
I have found 4 C size NiMH at home of the same make Ansmann so i'll take them to work and try those also.
I'll try different wire too and see what happens. Can't imagine a different make of 24AWG will make much difference but maybe a fresh go at soldering will give better connections?
Mettee did you measure the current through the tailcap?
Thanks Guys
Didn't we figure out that it almost certainly needed that extra cell for the voltage? And didn't your test confirm our suspicions?Should this driver work with 3 cells? If it does then perhaps my cells are not up to it.
I have 4 c cells at home so i guess i'll be modding for that now.
Annoying as i'd paid out for the D's and now can't use them unless at reduced power - mmm.
Righty-o
With the driver back in place and 3d NiMH the amps are 1.7 so up from before a little, whether that is down to better soldering or the fact the batts have had a recharge through them I don't know.
Threw a 4th d cell on top and bang 2.8A which is good as I know the driver is working fine.
Might put some more cycles through the batts and see if they come up more as they are pretty much new.
I find sunglasses are very useful when doing LED work at decent drive levels.Oh yeah, don't look directly at the emitter or you will see dots for a while.
Managed to do that just after wiring up my first Cree XP-G.Oh yeah, don't look directly at the emitter or you will see dots for a while .
What current is that measured at?Vf over LED is 3.35v.
The AMC7135 driver chips only specify a typical drop of 0.12V at max current (350mA/chip).I read somewhere that you need 0.6v higher than Vf to run the driver so I'd need at least 4v then?
Did I understand that right?
Righty-o
Or possibly got confused with the ~0.6 V drop across the polarity protection diode.The AMC7135 driver chips only specify a typical drop of 0.12V at max current (350mA/chip).
The 0.6V figure might have been making allowances for other losses or changing battery voltages, or referring to a different driver,
I dare say that'll only get it to run in regulation for a short time when the 3 cells are freshly charged. Because four flat NiMHs will give fewer volts than 3 fully charged NiMHs, 4 cells will likely drop out of regulation at some point too. How much current does it provide when the 3 or 4 batteries are half or almost completely flat? Is either OK?Have you tried eliminating sources of parasitic resistance so that you can run with 3xD NiMH in regulation?
