strebalicious
So I was thinking I could maybe take one of them Silverstar headlight things and put it in a flashlight. So I picked up the simplest looking bulb, which turned out to be an H7 standard.
Looking at the bottom it listed the bulb as an Osram 64210, 12V 55W. Luckily, the tabs on the bottom fit a quick disconnect female crimp just nicely.
Then, I ran over to the flashlights and picked up one of them lantern things like this one.
So my luck, the bulb fits pretty nicely in there. There is still maybe about 1/4 or so covered by the reflector (i.e., not sticking out of the hole). I figure later if I want to do more work on it, I can grind out the whole a little to get a better fit.
So I threw it together. An 8 AA battery holder fit in there perfectly, as the length and width of the holder matched the 6v mamajama battery. So I was able to hook up three holders in series for a total of 24 batteries (8 in series x 3). I had a butt ton of alkalines that I got for like .10 a piece so I just threw them in there.
And so here is the result (tested on the front door from about 8 feet away):
Before...
and After...
Overall, not a bad job for a quick experiement. A few problems to address should I rework/redo it.
1. The lens does not screw on so good. I think the wires are too long and are warping the plastic a bit. I think I could get a better fit using copper bars or something along the lines.
2. As I said before, maybe 1/4 of the bulb is still stuck in the whole. I could fix this with my dremel, should I bother.
3. Maybe use a different switch. I left it on for a few minutes and it didn't asplode right away, but I'm still skeptical about the sturdiness of the switch in there.
Before...
and After...
