gyzmo2002
Can you point out those premium cables kreisl, please?
A hint: Search for Braided Anker in this thread[emoji6]
Kreisl will be not guilty if they don't work.
Doesn't work on Android <4.3 devices.The Android and iOS apps are pretty poor.
- TESTED - bug: protection reset feature may not work in a slot after a finished charge program (UNCONFIRMED)
i have understood your observation, so i tested the function under the given conditions. the function works okay on my sample, i was not able to confirm your bug. maybe you could post a clear, reproducible step-by-step procedure which leads to the bug, something like...
:candle:
Ok maybe I've found why you haven't found the bug. It's present only after running a NIHM charge program (with LION no problem).
Before to go in detail:
I find that the protection reset feature very useful not only with protected lion, but also with dead (0V) NIMH battery. If the battery is not short circuited, by holding for 20-60s the slot button the current pulses sent by the charger are enough to "wake up" the completely depleted battery until it's recognized by the charger. After that it's possible to start a normal charge cycle to try to revive the dead battery.
Now the bug in detail:
1) I'm on fw 1.02, advanced mode. I didn't do a factory reset (I will do it only if you still cannot reproduce the problem).
2) remove all batteries, unplug charger from mains, wait 10sec.
3) re-power the charger, reboot to TOV.
4) Test the protection reset feature: without any cell in the charger hold the slot 1 battery button. After a few seconds you will see that the protection reset kick on and the voltage repeatably pulse to about 5V and the slot LED blink RED-GREEN. It should works without any problem.
5) Now insert a nihm cell in slot 1 and program a charge with 1A, capacity cut off off, time cutoff off, dv -3mv, temp cutout 45°C, all other settings off (in any case they seem don't care, is only important to select a nimh charge program).
6) Start the program.
7) After 10s or more stop it with the stop button.
8) Remove the cell and wait until "NO BATTERY" is shown.
9) Now try the protection reset feature by holding the slot 1 button. Now it should NOT work, nothing happen.
10) The protection reset of the others 3 slots should work.
11) If you put a LION cell in slot 1, start a LION charge program and then stop it and remove the cell, the protection reset feature should start to work again.
Thanks for the detailed steps, can others try this too please?
( i am non-stop cycling my new batteries, hopefully tomorrow i'll have a chance to test your procedure )
But what about the B?? Just looked it up. Those look like it could work. The + is not too covered and maybe slightly raised.
I can confirm @kappa7's results; after charging a NiMH in a specific slot, the protection reset feature no longer works in that slot until power down/up.
Although the beeps (sounds) remain whilst pressing Slot button there is no current being applied to the slot and thus no reading on the screen. I checked with a DMM.
Thanks kappa7 and Rapster, i was able to reproduce the bug, and submitted it to maker. It is very easy to reproduce, no FACTORY RESET needed, etc I've listed it under (k#27) and we should expect a fix in 1.04.
Very cute bug!!
Thanks Meyer, the bug #1 was already reported in Android app v1.0 by Winne the maker of DEX and then submitted by me ~2 months ago. We have been seeing app updates since, which is good. Too bad that the bug is still there.
I'll re-submit the 2 app bugs after CNY, no prob
Very cute bug!!
Which way does your fan blow?Just received my unit today from HKequipment. Firmware 1.3 Hardware version 1.4 Ordered 2/3, received by Chicago post office on 2/5. Took to 2/11 to get to Channahon. (received by Channahon Post Office on 2/11 and delivered to me on 2/11)
Only minor problem I have is that part of my shipment is missing. I hope it is just a oop's, and not a problem.
