Ferdinando
Re: SkyRC — IFA 2014 / CES 2016 — MC3000 charger-analyzer
@Kreisl is there a way to have battery-slot temperature logged into DEX ?
in my DEX default config (i.e. just installed DEX, connected to MC3000 without any personalization
Could you kindly tell me how did you do that? Thanks.
There is also a practical tip, when you're logging with DEX and all works fine and you want to, for some reason, close/exit/quit/leave/kill DEX, then you cannot just close DEX the application. One must stop the logging neatly with the DEX Stop gathering button first. Then you can exit DEX.I had some trouble in the past, but with latest DEX version and connecting MC3000 through usb2 port (avoiding USB3 ports) all worked fine.
Otherwise ...
And if all fails, simply restart the PC, restart DEX, and go.
The CVS version (the developement version of DEX) does log the temperature OK.
See source code here
https://savannah.nongnu.org/projects/dataexplorer
AFAIK
The latest stable version of DataExplorer is 3.2.6
and does not log T for the MC3000
i believe it is true that the 3.2.6 only logs BattTemp and not SysTemp.
i was able to update my installation with newer JAR file which does log SysTemp![]()
i've been logging with the 16th May build and you are right, the official 3.2.6 does not log BattTemp flawlessly:I used the CVS version for weeks, if I remember well 3.2.6 was logging 0 for BattTemp.
But my recollection could be wrong
I only used 3.2.6 very shortly
Indeed 3.2.6 did not log Systemp, you are right
it was added after 3.2.6, line 552 on 16th of May
Thank you, Kreisl! This restored DataExplorer temperature logging on my Mac.install the 3.2.6-16th download by overwriting your existing JAR-file
eh ben, i have never witnessed such strange MC behavior before and i am en vacances and not set to wrap my mind around the observation. of course there has to be a technical explanation for it and after careful examination of circuitry and physical sample some sky engineer would find it. however, if your unit works like that, strange, at any other mains socket and you're sure that the power adapter is working 100% fine, then we could already conclude that your charger has a malfunction.If i disconnect the USB the screen stop.
I do a factory reset and it's the same.
i send the new MC firmware V1.11 it's still the same.
https://www.youtube.com/watch?v=tYPwNk0NYek
