modamag
A few of you probably know that I collect flashlight for just the pure physical property of the light. Probably a few groove here and few slots there.
As I slowly migrate from a consumer -> designer -> fabricator. I found one of the most intriging aspect of how lights are produced.
There are bassically two schools of thought.
1. Keep everything loose and design for production (+0/-0.005") eg. MagLites
2. Keep them tolerance as tight as possible (+0/-0.001") eg Larry stuff.
Now both of these school of thoughts requires alot of time in either way.
=== The loose thinking ...
For these guys alot of design and modeling have to be done up front to ensure the "worst" case scenario still works properly. They probably spend 2-3x more for the design than most case.
But when it comes to manufacturing, with 5 thous tolerance they can just crank up the speed, bar stock feeder and run 24/7 ... well almost :nana:
=== The mens in tight gang ...
These guys have little need for modeling since on paper everything fits just right! Oring groove are a perfect 18% fit, walls are 0.010" thick, while thread pitch gap are just perfect that even water moisture don't even seep thru there, or do they. :devil:
When it comes down to making it, they whip out their pin gauge, thread pitch gauge, keep a thermometer near by and spend hours on ends measuring and test fitting to ensure that the right "feel" is there.
So what is this all about? Well I would just like to know which groups of tolerance you are in.
Mens in tights ... 0-0.001" tolerance
Mens in reds ... +/-0.005" tolerance
I own a ruller ... 1/16" tolerance
That looks right ... minimal use of measuring devices.
I originally was in the red (chinese machine), then went to the tights, but recently found a way to appreciate both schools of thoughts.
