Linger
My incans are for enjoyment, walks in the woods with family, or through the park just as an excuse to use them.(I have a led on me for any 'need')
I'm planning on an AW soft-start for M@g D. I've have a few different combinations for the M@g: ROPs, to WA's, Carly's, to the new wunderkind Hikari 5607. And some different power supplies: 8aa'a, 14500's, IMR (16340, 18650, 26500) 25500, 26650, etc...
With the multi-mode I expect the brightest become more manageble when I can turn them down, also the somewhat longer run-time from using lower modes is nice.
My question is if I am already spending $75 on a soft-start, would I be better served going with the regulated driver instead?
I understand the driver will give me longer at max as I could load up with the big lithium cells. But I don't see myself needing long run times on high. It would be nice to know I could get 1500lumens at the click of a switch, at any time. But I also get by fine with the gradually declining output.
The driver would be pre-set (I'm not allocating time to learn the reprograming) and I would lose out a lot of combinations. There's a work-around - I just port over the higher power items into the 3D M@g if the driver will work with different bulbs.
Question: Is it possible to use a few different bulbs with one driver, e.g. if it was set for 11.8v as max, could I swap between 1166, 1185, JC5607, etc...
How is the regulated driver best used? I feel that at this point AW's soft-start may serve me better as it has more instant flexibility (no reprograming required). Is the regulated driver best when a single configuration, like an FM mega host with a 100w bulb?
Thanx,
Linger
Thanx,
Linger
