Some
length info for
Solarforce:
(1x 18650) = (2x CR123) = (
L2)
or (
L2M + 1x 123 extender) [
L2-ECR, included with new L2Ms]
(2x AA) = (3x CR123) = (
L2 + 1 123 extender)
or (
L2M + 2x 123 extender)
or (
L2M + 1x 18650 extender) [
L2-E18]
Always consciously verify you have the correct polarity and voltages - confirm the drop-in matches the voltage presented by the batteries. Always match batteries for type, brand and state of charge in multiple battery setups.
Recent Solarforce L2 series accept 18mm diameter cells, older ones won't. The recent ones will leave a lot of room around AA cells. O-rings, paper, tape or a plastic sleeve are common methods of taking up the space and preventing battery rattle.
This is conceptually applicable to other brands.
Cell Sizes:
18650 = 18 mm diameter, 65 mm length, 0 = cylindrical
18500 = 18 mm diameter, 50 mm length, 0 = cylindrical
16340 = 16 mm diameter, 34 mm length, 0 = cylindrical (CR123)
14500 = 14 mm diameter, 50 mm length, 0 = cylindrical (AA)
Thus body & extension lengths end up as...
2x 14500 (AA) = 100 mm length
3x 16340 (CR123) = 102 mm length
1x 18650 + 1x 16340 = 99 mm length
Notes:
- All measurements are nominal.
- Springs make up differences in length.
- Protected LiIon cells are typically slightly larger, although they will be referred to as being the same size usually - they are made with a standard cell with a small circuit board added at the end and a conductive strip running up the side to the positive terminal, which has to be insulated from the body (can) of the battery.
End result:
If you buy a new Solarforce L2M, which normally includes an L2-ECR, the L2M by itself will take a CR123 or RCR123 (rechargeable).
The L2M plus the included L2-ECR will take an 18650, and you can buy either an additional L2-ECR or an L2-E18 to use 2x AA cells.
If you buy an L2-ECR, then you'll use the L2M plus 2x L2-ECR for 2x AA.
If you buy the L2-E18, you'll use the L2M plus the L2-E18 for 2x AA.
Future considerations:
Buying the L2-ECR will allow you to use the L2M + 2x L2-ECR with 2x 18500 LiIon cells for higher voltage dropins (greater capacity than 2x RCR123) at the cost of additional length.
Buying the L2-E18 will allow you to use the L2M + L2-ECR (included) + L2-E18 for higher voltage dropins that would benefit from the even higher capacity of 2x 18650 LiIon cells, with some further additional length.
- Syncytial.
P.S. - I've read too many of TTA's posts apparently!
