csshih
Solarforce Masterpiece Pro-I "C" Turbohead Review: Pictures, Beamshots, and more!
Hi Everyone,
Up for review is the Solarforce Masterpiece Pro-I , a "C" threads compatible turbohead.
Here are some of the specs from Sbflashlights.com
**IMPORTANT INFORMATION: To reduce the risk of damage please install the Solarforce Masterpiece Pro-1 Head first, then insert batteries from the tail end.
here is the light:
here is the head, sitting in front of a bunch of lights
very well fluted head-- edges are sharp, but no razor or misshapen edges.
Size Comparisons:
Comparison Beamshots:
holes are typical -- throwers don't look good close range.
White Wall Shots:
Shutter Speed is not specified -- the white wall shots are meant to show artifacts, rings, etc in the beam, not for brightness comparison.
Outdoor Beamshots:
Runtime:
interesting jumps. I am unsure why the light does this, it looks like an attempt at better regulation?
I am unable to do a runtime on 2xRCR123A, I currently don't have 2 AW cells on hand.
Impressions:
The Solarforce Masterpiece Pro-I is Solarforce's first attempt in making a C-compatible turbohead. It does not disappoint. From my archived beamshots, it appears to beat the Tiablo A10-G in throw. Interestingly enough, it appears that the Pro-I either uses a smiliar or the same reflector as the A10-G, as it fits perfectly in the ACE-G head (A10-G/ACE-G had compatible parts). I don't have the A10-G anymore, so i'll have to depend on someone else for comparing. The disadvantage I see with this head is with it's performace on a single Li-ion cell, the head drives the emitter at a lower current at the lower voltages.
The head pairs very well with a Solarforce L2P body, there are no gaps or any oddities when the head is attached. Attaching the head, though, makes the light top heavy -- I recommend you purchase a clip along with the head to help with grip.
Sadly, the dropin isn't really a standard one, but proprietary, but, I am under the impression that Solarforce is in the process of creating a SST-50 dropin for this head.
There really isn't too much to write about an attachment -- the pictures should speak for themselves.
link removed
Hi Everyone,
- Complete flashlight head assembly product with premium CREE XR-E (WC-R2) LED
- Powerful and extreme output up to 275 lumens*
- 18650 battery x 1, at approx. 200 lumens: 2.5 hrs
- 18650 battery x 2, at approx. 275 lumens: 1.5 hrs
- High strength aluminum alloy body with Mil-spec hard-anodized finish
- Max. Input voltage: up to 16V for high flexibility in battery configurations
- Length, largest diameter: 82.5mm, 57mm
- Weight: 185g
here is the light:
Size Comparisons:
White Wall Shots:
Outdoor Beamshots:
Runtime:
Impressions:
link removed
