FOR SALE: Aleph III Quad SSC P4! This light is a conglomeration of various parts and ideas from various modders and suppliers from around CPF. The light is a lightly used shelf queen. Never carried, only used around the house a bit. It remains in perfect condition.
Specifications:
-HEAD: Aleph III head originally build by Icarus as a Quad-Lux III. The light is fully regulated and optimized to run off of 3xR123s (please use protected cells). The head provides 500 mAs to each emitter. More recently the head has been modernized by CM who replaced the Luxeon III emitters with SSC P4s. This pretty much more than doubled the output while maintaining the same runtime. At 500mA per emitter the 4xSSC should be putting out between 550 and 650 lumens!!!
-BODY: Custom built 3x123 body by Tranquility Base! The anodizing is a great match to the Aleph head.
-TAILCAP: McE2S build by McGizmo. Provides two output levels with push button momentary on switch recessed in protective button guard. Push the button down to get low, little harder for high.
-BEZEL: Custom built Aleph III Ti Bezel ring by Tranquility Base!
So there you have it, a custom light with input from four respected CPF modders and builders: Icarus, Tranquilitybase, CM and McGizmo!!!!
$500 + 4% CC PP Shipping included CONUS
