Yeah, you could do that. Personally, I can't resist tinkering with lights, even if they pay the ultimate price in the process.
How about an easier solution? The Sandwich Shoppe sells the SMJ2 AAA Solitaire modules. It is "plug and play".
No modification to the is Solitaire required, and you can even carry your spare bulb in the tailcap as a backup.
Simple: some of us like to tinker with stuff.Just out of curiosity, why do you want to do this modification?
Welcome to CPF, poppeye.
That particular mod entails exchanging the stock bulb for a 3mm LED. To power the little beast, you'll need an A23 battery (they're 12V, used in garage door openers). That battery is the same thickness as a AAA, but it's shorter, so you'll need to make up a spacer to make up for the missing length. The spring from a mechanical pen, a screw cut to size, or even a long wad of aluminum foil should work.
Hope that helps. That mod is not very bright, but the LED will glow for a looooooong time.
i dont understand the 3mm soltaire mod on flashlight review 2?
