KC2IXE
Production job for someting I'm hoping to sell
Here is the part that made me say "hummm"
Job is run on 3/4 6061 - and I have to turn a boss .140 long to .380 diameter. My choices of tools
1)Hss ground anyway I want
2)a CCxT insert in the 21.5x size - aka SMALL, but I have fancy grades, breakers and the like
3)A good old TPG-22x insert (or TPMR-22x) insert set square to the work
I quickly discovered that you are NOT taking much more than a .060 or so cut with the tiny 21.5 inserts - you're just NOT
Grab the TPG-221 with a nice polished insert - no breaker at ALL, except the one built into the tool holder
Two nice passes - one at .150 doc, and then the rest as a finish cut. That .150 cut was deep enough to get into the holders chip breaker (.120 or so wasn't) and that .035 was a nice cleanup pass. Quick, easy, 2 passes vs 5 or 6 passes with the little tool
(Guess I have to get myself some larger holders, eh?)
(Oh, and yes, this was being done at 1000rpm on an Atlas lathe - not exactly known for being the most rigid setup. Human screw machine - what fun and joy)
