StefanFS
This is not a step by step mod, it's just a few pointers. The objective is to put a better driver into your average Raidfire Spear or RQ flashlight.
The first step if you are to use a driver with components on both sides are to enlarge the upper part of the tube with a reaming tool, this is sometimes called a stepless drill bit. Since the inner lip on the tube presses the driver in place and provide ground it's best to leave the inner lip about 1.5--2 mm thick (depends on which driver you use.
Next step is swapping the driver, I use what is known on DealExtreme as sku 7882 which is a boost driver that work well with one 18650 LiION. It has three groups of levels and usually I use the group with low-medium-high. But for this light I'm going to mod it to a single mode driver as it's going to be a safety light around the house and one level is enough when adrenaline might be involved.
Just pressed into the pill, setup with wires soldered to led + & -. This mod also need a longer spring on the driver, I just used a spring similar to the original and soldered it to the existing one. It pays to have extra stuff laying around.
On the left is the latest version of the driver, the white one I use is from the first generation. Between these versions there was a variety that was optimized for 1AA and that also needed a solder bridge to work, avoid the middle version as they have huge battery draw with one LiION.
How it looks on the upper side with wires to the emitter, neg. on the right and pos. on the left. This is the standard wiring. To make it one level I drill the hole for the neg. connection bigger with a fine tipped dremel-type diamond cone tip until a 26 AWG wire can go through to pin 4 on the PIC that's on the other side.
Other way around, pos. on right and neg. on left. Another angle.
The one level variety, closeup.
Down into the tube. See how the inner lip of the tube holds the driver in place.
My kitchen table setup for this little exercise.
With the driver tuned to ~1.25A it throws ~29 000 lux at one metre. My Dereelight DBS (with an identical driver and the same Cree Q5 bin) set at that level is ~32 000 lux or so. Battery draw is ~1.6A. So I'm very satisfied with this little modification. The stock AMC7135 ~1A driver managed ~18 000 lux on one 18650.
Battery draw & output in terms of throw @ 1 meter.
1 x AA NiMH GP ReCyko (with spacers):
1.44A and 12 800 lux
18650 AW:
1.43A and 29 000 lux.
2 x CR123 Panasonic:
1.60A and 30 300 lux
Stefan
18650 AW:
Stefan
