PEU said:
Epoxy doesn't stick to Scotch tape. I use it to wrap around sammies before filling them with epoxy. Make sure to use the "real" Scotch tape and not the generic kind... things *may* get messy (don't ask, it hapenned to "a friend") with the generic.xochi said:Once dry, remove the tape and hope that the adhesive didn't get into the epoxy and that removing the tape doesn't pull the thing out.
leukos said:xochi, I wonder if the Ti ring would fit better on an HDS with the 1mm saphire lens from the Shoppe....
PEU,
I'm a little confused if these rings will come with tritium installed, or if this will just be an option. If so, will there be other color choices than green?
