streamlight has a new lightbox hid on their site(under lanterns). botach has it for $450. copy of their description:
The One Million Candlepower High-Intensity Discharge Search Light that Illuminates Objects One Mile Away! The H.I.D. LiteBox® has the intensity and peripheral illumination to light an entire scene; plus navigation LEDs for low-light maneuvering. Ideal for field maintenance, inspection of construction sites and remote equipment, it's a heavy-duty, rechargeable, completely portable high intensity search that does it all.
* Deep-dish parabolic reflector produces a long range high intensity focused, one million candlepower beam
* Optimum peripheral illumination for scene lighting
* Fully articulating head can be aimed precisely at target
* Two White Navigation LEDs
* 35 Watt H.I.D Xenon lamp: 3350 Lumens, 1,000,000 Peak Beam Candlepower; 2000 hr. min. lifetime
* White 5mm LED (x2): 9 Lumens (each), Impervious to shock with a 100,000 hr. lifetime
* Runtime: H.I.D. lamp: up to 1.75 hrs, LEDs: 100 hrs.+
* Groove for IR filter
* Cushioned-grip handle
* Integral D-rings allow attachment of the included shoulder strap
* Elastomer impact bumper
* High-impact ABS thermoplastic housing and weatherproof construction
* Fits existing LiteBox® Mounting Racks
* Zero-maintenance 12V, 7.2Ah sealed lead acid rechargeable up to 500 times
* Serialized for positive identification
* Available in International safety orange or black
* Length: 14.9 in. (38 cm)
* Body Width: 5.1 in. (13 cm)
* Overall Height: 8.8 in. (23 cm)
* Head Diameter: 7.7 in. (20cm)
* Weight with battery: 10.1 lbs (4.6 kg)
* One year limited Warranty
