Streamlight Strion/Surefire 6p
notsosurefire
How would you guys compare these two flashlights?
I don't know enough about the Strion, does it have Tailcap lockout, tailcap push momentary on etc.
And, is it BRIGHTER!!
(I do know that it is rechargeable)
Cheers!
my moms got the strion its really bright but the run time sucks i would go with the 6p and get a 3watt or higher drop in led bulb
The Strion doesn't have a lock out tail cap nor is the beam fixed - it's adjustable, which some guys do prefer...but I hate it! Also, rechargeables will quit on you just like a non-recharger...BUT...with a non-recharger, all you do is pop in another pair of batts - BOOM! Back in business! With a re-charger...you are just GRAVE-YARD DEAD!
I'd go with SureFire.
Quickbeam pretty much nailed it.
I have both; my first "good" flashlight was a 6P, and when I got tired of replacing the expensive lamp units and batteries I bought the Strion.
The Strion is slightly brighter, and has a smaller, more defined hotspot; the 6P has a larger, less defined hotspot and more spill. The Strion definitely out-throws the 6P. Beam quality is on a par, though as noted it is different.
Strion build quality is slightly lower than the Surefire, but it's still a superbly made light. Unlike the 6P, the bulbs seem to last forever; I've had mine since they were first introduced, and I'm on the original bulb!
The Strion is "focusing", but not like a Mag is; I used the focus feature to fine-tune the beam quality, then left it alone. The focus ring is quite stiff, and in several years of use has not budged accidentally.
Bottom line: when I got the Strion, the 6P went into the storage drawer. I've been very happy with mine.
-=[ Grant ]=-
Grant,
Your experience with 6P (P60) Lamp Assemblies is not consistant (the opposite in fact) with the feedback people give on the life-spans of their SureFire Lamp Assemblies both here on CPF and elsewhere.
Did the lamps die as a result of dropping the flashlight?
I believe strion bulbs are much cheaper than the surefire replacements anyways. Which earns a big plus in owning a low operating cost flashlight. Who wants to keep buying CR123's :rolleyes: unless you really have no other choice.
Get the 6P and then get a Cree or 3W LED drop in if you want a nice upgrade. I have a few Streamlights that make great paperweights...Streamlight is not even in the same class as SureFire.
greenstuffs said:
I believe Strion bulbs are much cheaper than the SureFire replacements anyways. Which earns a big plus in owning a low operating cost flashlight. Who wants to keep buying CR123's :rolleyes: unless you really have no other choice.
The prevailing consensus is that SureFire Lamp Assemblies have significantly longer life-spans - spare bulbs are not required in the same way they are for other lights so you don't get through nearly as many lamps.
I feel the other issue of primary vs. rechargeable batteries is much more to do with personal circumstance and taste which separates us CPF Flashaholics from the "dutylight" users of flashlights who actually need a rechargeable light.
My own personal taste is for the convenience of primary (SF123A) batteries.
I find it annoying to be a slave to a recharger. It is inherently inflexible, takes time and effort, and saves only a token cost of purchasing SF123As - a consumable I have never considered to be expensive or cost-prohibitive to my enjoyment of flashlights.
I tried to use a rechargeable EDC for a couple of months. It saved me perhaps 24 SF123A's ($42) (£20-25) which is a cheap meal out or an evening for two at the cinema. For me it is a small price to pay for my EDC.
I really didn't like having to lug the charger and mains supply around, nor having to return to where it's at, nor the time it takes to recharge the batteries. I had to force myself to remember and physically put the battery back on charge. And then to reload the battery before grabbing the flashlight for the day. I didn't like not having lots of spare batteries ready for use, nor not being able to go to a shop any buy replacement batteries on the fly.
I feel that if you need to use a flashlight for an hour or so everyday (or night!), or if you use a lot of batteries and can't stomach the cost then a rechargeable solution is better for many applications.
Rechargeable EDC does not float my boat one bit - my EDC has to be effortless, quick & simple. I'd take a 6P over a Strion without hesitation.
(I wouldn't take either since I prefer the G2 to the 6P, or better yet an E2e. For EDC my incandescent preference is for the A2)
Al
I have a strion that gets used very often, I had it since they were first available, have never had to change the bulb and its been droped a few times and is showing more silver as time goes by. I also have 3 g2's which mostly never get used but are in strategic places and ready to go to work on a moments notice. The strion does have a longer reaching beam than the g2 and it costs virtually nothing to operate. The g2 beam covers a much larger area though and if running through some woods or searching through a house at night, Id go g2 hands down. It depends a lot on what you need the light for and as others have said about rechargeables, I would not dream of going out at night with only a rechargeable. Of course I always have an A2 and and HDS edc with me at all times so if the strion dies (and it has) I'm not left out in the dark. The strion is my go to general purpose light and has proven to be very dependable, useful, and economical.
First off I agree with Size 15's that primary CR123's are the way to go for 90% of my lights. I do have a couple rechargeables, but they are setup with LED's for longer runtimes. If you definately want a rechargeable there are several options for the 6P. Depending on what you go with cost may be more than the Strion, but you will be happy with the outcome.
1) 6P + two RCR123 BatteryStation (900 mAh each) rechargeables + Cree dropin ($50+$20+$40=$110)
2) 6P + one 17670 (1600 mAh) rechargeable + Cree dropin (similiar cost as option #1)
3) 6P + one 17670 + KL3 LED conversion (LED runs about $55)
so hope this helps your decision. If you decide to run non rechargeables you can get about 2+ hours out of a set of batteries with CR123 non-rechargeables.
Just wanted to add that if you prefer incandescents, there are rechargeable options for the 6P from Lumens Factory, Wolf-Eyes and CPF retailer AW. All can be used with 17670s or Pila 600s (I think that's the correct model #).
Size15's said:
Grant,
Hmmm....not sure whether you're questioning my veracity or my sanity! ;)
I have some experience with SureFire's lamp assemblies. I've owned 2 lights (a 6P and the "Combat Light" version - the 6Z, I believe - which was later sold off), and my wife owns a 6P as well (a "gunmetal" version, still SF's best looking light ever.)
On Day 3 of being a SF owner, I turned my 6P on and laid it on our coffee table; it rolled off, onto a carpet floor, and the LA failed.
A couple months later, I was in a doorway; someone called my name, I turned quickly, and my holstered 6P hit the doorjamb; the LA would no longer light up.
Roughly 8 or 9 months later I was camping in a very remote area of Oregon in a pouring rain. I'd been using the light off and on all night, and one time I pushed the button and the LA blew.
My wife was participating in a low-light shooting match in which she was seated at a table. The scenario was to draw light and handgun and engage several targets. She drew the light as she began to stand, her 6P bezel hit the edge of the table on the way up, and failed to light.
I've watched as someone who was using a Combat Light on a lanyard dropped the light to facilitate a mag change (light being lit); his ejected magazine hit the dangling light, blowing the LA. I could go on, but I've no doubt caused the SureFire contingent to see red as it is!
After replacing so many lamps, I looked for something that, even if it should prove no more reliable, would at least be cheaper to feed with bulbs. When the Strion became available I bought two - one for me, one for my wife. This was when the had first come out; even the wholesaler, who was a StreamLight service and parts center, hadn't heard of it yet. That was what - 3, 4 years ago? Well, as incredible as this sounds, BOTH our Strion are still on the original bulbs!
We treat them no differently than we did our SureFires; my personal Strion has deep nicks gouged out of the bezel, for instance. I can't count the number of times I've dropped it and hit it against something. My wife has carried and used hers daily since new. Neither has yet failed.
Matter of fact, we use the Strions even more as a general illumination tool than we did the 6Ps, primarily because of the economics of running rechargeables - so they have more active hours on them than our SureFires did. Again, I stress they are still on the original bulbs, a claim which neither of our Surefires can make.
I've been assailed by SureFire apologists before. I tell them the same thing: I like SureFires, but they aren't perfect - no matter how much one wishes they were.
Am I hard on lights? Yes, but no more than one would expect for a light supposedly designed for "tactical" environments. I'm sorry, but saying that a lamp for such a light works fine "unless its been dropped" is like saying that a failed firefighter's helmet "works fine as long as it doesn't get hot!"
As to reports of people getting much better life out of SureFire lamps, I can only surmise that they're either padding the truth, or they work in an air-conditioned office and take their vacations in nice parks with paved walking paths. I do neither of those things.
A light to me is a tool, no more; I don't collect them, fondle them, talk to them, take them out to dinner, store them in velvet-lined cases, or sit them on shelves where they can be admired my passersby. I use them, often in rough environments, and to me their sole value is in how they survive (or fail to survive) the use to which I put them. From that perspective, my experience with SF lamp assemblies is less than confidence inspiring.
Sorry if such a conclusion disturbs anyone's sensibilities, but it's been my experience, and I offer it up only as the data point that it is.
-=[ Grant ]=-
Thanks for sharing your experiences. It certainly seems to explain why you looked elsewhere for an incandescent light - I'm sure most people would have done the same. On balance I still feel confident in the robustness of the P60 lamp assemblies. More confident than in the Strion because there is very little feedback on them compared to the many years the P60 has been around. It does appear that the Strion is a much improved animal compared to the Scorpion. A newer bulb would appear to make a significant difference.
SureFires and Streamlights are both tools - designed and intended for use. I gain my experiences and opinions of SureFire durability from putting plenty of them through abusive field-testing over the last decade. This includes the P60 and P61 lamps in the G2, G2Z and the M2 being pushed way beyond the call of duty.
I've been disturbed for years and I've got some ointment for my red sensibilities...
Al :)
Just a quick testimonial for the strion, I bought mine as kind of a skeptic. It is my new edc, my c2 centurion sits on my night stand now. I was at my best friends house this weekend in northern Ontario. The ground is till frozen but the snow is melting. I lost my strion on friday sometime when I got there. Looked everywhere, I found it sunday afternoon turns out it fell out of my pocket in the truck and fell out onto the driveway when I opened the door, When I found it it was jammed into the frozen gravel under water. I ran it over with my f150 twice before I found it 2 days later. I took it in the house and rinsed it under the tap. It still works absolutely flawlessly despite some scratches.
I am a believer In streamlight products but surefire aswell but the battery $$ burns me, not with the strion though! goes on the charger evernight and I never worry.
Ben
ben_mm7 said:
...my c2 centurion sits on my night stand now. ...I am a believer In streamlight products but surefire aswell but the battery $$ burns me...
You know, you could replace the LA in the C2 and run rechargeable batteries in it. See here for an example of how to do this.
I wonder if the 6P's throw would improve if it had a tempered glass lens like the Stinger.
The Strion is a rechargable only light. When your battery dies your light has to go back on the charger. This means your light is now out of commission. Having used Streamlights extensively for work ,I am sensative to this.
I think the Strion is a very fine light. Most of the tool Streamlights are. Carrying the Strion and say a Fenix P1 on your keys should pretty much cover you for EDC.
I use Surefires because I can use both rechargable and primary batteries when the rechargable dies. The 9P is a good example of this. You leave the light stock and use two 17500 li-on rechargables. When they die off you can use others that you may have recharged or you can use 3 123's.
With the 6P/C2 's you replace the bulb with a Cree drop in 3.7 to 6 volts and now you can run 17670's or two 123's. If you replace the whole bezel and bulb with a Surefire KL3 you can also run the 17670 or 123's.
With the E2e with a KL1 head or the L4, you can use a 17670 or 123's.
With Surefire you can EDC your rechargables but have the capability to put in primary's when your rechargables die or get low. This option becomes terribly important if you are subject to situations that do not permit you to quit what you are doing because your light needs to be recharged. First reponders really need this type of capability. Even though rechargable Streamlights are widely used, very reliable and have a respected reputation in the First responder occupations, most always have another light available for just this reason.
