Ryanrpm
Next in the lineup of Sunlite products is their new FP80 in the 53mm diameter head, just like their 16wFP.
Here are the specifications for this light.
Specifications
Brightness - 550 lumens (Turbo), ~130 lumen (side switch)
Size - 9 inch (228 cm) in height, LED head: 53 mm in diaemter, Housing: 25 mm in diameter
Weight - 10.1 o.z. (287 g) (with battery)
Power source - 5200 mAh Li-ion rechargeable battery
Charger - AC charger, optional 12 volt car charger
Run time - 1.5 hours (Turbo mode)
Recharge Time - 6 hours
Color - black, Type III Hard anodized
Others - Water resistant and shock resistant
Overview
Features
So, besides the Diamond Dragon emitter, and these new Phlatlight LED's which are popping up in new flashlights, the Sunlite FP80 employs a single emitter that is 80 mils wide, or 2mm x 2mm.
Again, for those who are new to Sunlite products, their main shining points that set them apart from all other flashlight makers are the following combination of being: Rechargeable - they have a charge port located opposite the side switch just under the head. Versatile - Different heads can be used on the same power source body. Safe - Sunlite views safety as their top priority when designing their lights...knowing that they go into the hands of LEO's, mechanics, and the general public. Using Custom LED's - Sunlite manufactures their own LED chips and wafers, therefore, allowing them to make their lights AS. (Application Specific) So the technical name of their LED's are: AS-LED.
I'll begin this review with some pictures of the emitter itself. Nothing has changed as far as external design from the 16wFP. The FP80 utilizes the same housing, heatsink, etc....and only the reflector and emitter/module have changed.
That is about as close as I can get to getting a picture of the emitter. I held a magnifying glass and everything. Notice that to the left of this above photo, there is a crescent moon shaped gold patch. I have no idea what purpose it serves, other than to possibly disperse the bonding wires to the emitter. Also notice there is no glass dome. Sunlite does not encase their emitters in a protective dome like Cree, Seoul, and others....instead, they spread a layer of clear thermal epoxy over it.
The next series of photos is some outdoor shots I took tonight, showing it's long range application. I also compared it to some JetBeam models, namely the Raptor 1 and the M1X. And I threw in the Spear clone, the RQ.
Here is the lineup:
Next, is some individual shots of the emitters:
M1X - Cree MC-E
Raptor 1 - Cree R2
RQ - Cree Q5
FP80 - 1 x 80mil (2mm x 2mm)
16wFP - 4 x 60mil (1.5mm x 1.5mm)
8w - 1 x 60mil (1.5mm x 1.5mm)
The Setting: This tree is an ideal location for me, with very very little ambient light from the city, and not a lot of traffic either. The tree is exactly 600ft away, which is a fair distance for comparing "Throwers". I just took a single shot of each, and then did a side by side comparison of the Raptor and FP80, since they are the 2 closest when comparing "apples to apples".
The JetBeam M1X:
The Raptor RRT-1:
The RQ:
The FP80:
The 16wFP:
The 8wFP:
Side by Side comparison of the Raptor and FP80:
(Raptor on Left, FP80 on Right)
Smaller images so you can see side by side comparisons:
M1X and 16wFP:
FP80 and Raptor:
FP80 and RQ:
FP80 and 8wFP:
FP80 and M1X:
FP80 and 16wFP:
Well, thats it for now. I'll capture some whitewall shots so you can see the beam profile.
I did manage to get ceiling bounce numbers for you guys.
Here they are:
RQ - 10
8w - 12
Raptor - 13
FP80 - 22
16w - 31
M1X - 32
Thanks for looking........ask any questions and I'll try to answer them. Also, let me know if you have any picture requests as well.
Specifications
Overview
- FP80 Rechargeable LED Flashlight includes battery, AC charger and Belt Pouch SNLBP53L.
- FP80 employs a 80mil single-chip emitter.
- FP80 offers super tight center beam, throws further than 8WFP.
- FP80 comes with SMO reflector
- Side switch offers ~130 lumen, Turbo switch offers 550 lumen
- Runs 2 hours on Turbo switch.
- FP80 efficiently drains heat from the LED chips, and efficiently conducts heat to the fins and the flashlight body.
Features
- Super tight beam for far projection, throws farther than 8WFP
- More spill compared to 8WFP
- Copper substrate to quickly drain the generated heat. The thermal conductivity of our LED is around 1'C/W.
- Fins to enhance the heat removal
- Aluminum reflector, also helps to drain heat away from the LED
- Type III Hard Anodized aluminum alloy housing, also functions as heat sink.
- Toughened Ultra Clean Glass Lens
- Dual switches
Here is the lineup:
M1X - Cree MC-E
Raptor 1 - Cree R2
RQ - Cree Q5
The JetBeam M1X:
The Raptor RRT-1:
The RQ:
The FP80:
The 16wFP:
The 8wFP:
M1X and 16wFP:
FP80 and Raptor:
FP80 and RQ:
FP80 and 8wFP:
FP80 and M1X:
FP80 and 16wFP:
Here they are:
RQ - 10
8w - 12
Raptor - 13
FP80 - 22
16w - 31
M1X - 32
