Chrisdm
- Joined
- Mar 10, 2011
- Messages
- 917
Re: Sunwayman L.E. V10R Ti2 Gold (or black)...what was your "out of the box" conditio
Yes, the Ti2 button grinds & sticks unless it is depressed straight down. Bummer. At first I was hoping this would cure itself after use, but instead I put a kuku electronic switch in it.. And yes, there was obvious machining done after the finish was applied: Particularly the grooves in the handle, but also the numbering/lettering. This is a likely point where the blemishing to the finish occurred. But of course I'm sure Sunwayman already realized this, if in fact they are looking into the problem (I hope they are!)
Regarding titanium in general, it is easier to appreciate if you look at an unfinished sample side/by/side with aluminum: Not only is it much more visually appealing, but it feels smoother and it wears much better (finish marks etc can be rubbed out). Regarding the black Ti2 specifically, this type of coating (AlTin) is unique to titanium and from what I've read is even more durable than the typical hard anodizing performed on aluminum, plus is MUCH nicer looking IMO.
Out of the box condition of my V10R Ti2 Black some more observations and questions.
* Grinding crunching sound from the button. None when the button is pressed straight down. I get the sound when my finger is off to one side. It sounds like the button is rubbing on the inside when depressed at an angle.
* Did any one else look closely to see how the shiny groves were made it looks like these were polished after the anodize process as small burrs were left and can be felt by running your finger along the barrel. The scratches the "Goldies" have may be part of the post anodize machining process.
* Light color this one is even colder compared to my V10A, my V10A has warm tint compared to the Ti2.
* Hot spot on Ti2 is tighter and more defined than V10A. V10A is a smooth flood the Ti2 is more of a spot. The spot came at a cost there is now a dark shadow around the corona. Comes under the category of being careful what you ask for. There were many complaints about the floody beam of the XML compared to the XPG. I see this as an attempt of SWM to give more throw. My comment to those who were whining about the XML vs. XPG did you even compare the size of the active area of the emitters?
* Clip still needs to go through a tumble polisher before the finish is applied to remove burrs.
* Running the V10A and Ti2 side-by-side both on LiCo 16340 & 14500 the Ti2 appears brighter, via ceiling bounce test. The cells were straight off the charger.
* The V10R-AE neutral is considerable dimmer compared to Ti2.
* I need to buy new 18650's for my V60C so I think I will try IMR 16340's for my two V10R's.
* This is my first Titanium flashlight and first impression is other than the "bling" factor I'm not sure the extra cost is worth it.
=D~~ Kilted
