Superlights shoot-out: The ShortArcs
ma_sha1
CT, USA
Quite a few years back, in 2004, there was a superlights shootout by CPF' old timer kenshiro:
http://home.earthlink.net/~kenshiro2/superlights/superlights.html
a stock Gen II Maxa Beam Short Arc was the longest throwing light of the group.
(I have 2 Gen II Maxa Beam, they measured 2.3 & 3.2 Million CP respectively)
fast forward to 2011, In this shoot out, the Maxa Beam is the bottom of the bunch :devil:
The Lights
Left: Gen II Maxa Beam #2, with upgraded Gen III lamp, 6.1 Million CPs/1800 Lumens
The shoot out was done on the Hi mode ~4 million cps (not the 30" burst mode).
http://www.candlepowerforums.com/vb...ated-Short-Arc-amp-HID-spotlight-Lux-readings
Middle. Mega Blaster, 120W P-VIP short arc, 5 Million CPs, ~7000 lumens, build thread here:
http://www.candlepowerforums.com/vb...-arc-mod-MegaRay-style&highlight=mega+blaster
Right: Moon Blaster, 120w P-VIP short arc, 16 Million cps, also ~7000 lumens, build thread here:
http://www.candlepowerforums.com/vb/showthread.php?307615-Blitz-Short-Arc-The-Moon-Blaster
The Destination
The Beautiful Fort Gorges:
Shoot out is from a pier about 0.9 Mile away
First Up: Maxa Beam
with 10x Optical Zoom
Second up, the Mega Blaster:
Last but not least, the Moon Blaster
Zoom in slightly
Optical + Digital Zoom:
scaled.php
How about a Fun Shot to end the shoot out: Moon Blaster hitting the Atlantic Ocean Surface :devil:
That's it folks
ma_sha1
CT, USA
Re: Superlights shoot-out 2011: The Short Arcs
I can see them, maybe you have pic loading issues?
N10
Montreal
i can see them also. does anyone know the new otf lumen rating of the maxabeam since those seem to have had updated/upgraded electronics and reflectors from what i've read from other threads.lack of lumens is where maxabeam is losing in this test right?
2100
SINGAPORE, South East Asia
The maxabeam really looks like a slightly out of focused 445nm laser.
Anyway damn cool shots! I have the camera settings here, 6.5s f4.9 ISO200. Will try to get some pics of 1.5km at that setting with my 250W lightpipe. Very very rough gauge but hey any info is useful - we are afterall halfway across the way from each other!
Actually we have a Maxabeam/SR90/many many cool lights owner here (think he has played with over 100 commercial lights LOL!), but seems like he is busy. We were supposed to meet.
ma_sha1
CT, USA
The losing to Mega Blaster is indeed due to lumens, the lux is similar but the Mega Blaster has about 4 times the lumens in the beam, making a much stronger light saber. The moon blaster is several times higher in lumens as well as beam candle power over Maxa Beam.
Thanks! Would love to see LP250 vs. Maxa Beam, would also love to add 70 to 100 meter lux readings to my cp collection thread!
Lightpipe 250 is about 18000 lumens on 5mm? arc. ~ 3500lumens/mm arc . 4" ID
Mega Blaster is 7000 lumens on 1mm arc, 4.5" ID, 5 Million beam candle power
I'd say the Lightpipe if done right should be about 2-2.5 Million cps, half the beam candle power of Mega Blaster, but twice the lumens, it should be able to lit up a 1.5KM target.
The Moon Blaster with much larger reflector, also 7000 lumens per mm arc, pumps out a lot more beam candle power.
My project in progress, the home made portabe tank light, weight in only ~15 lbs, (VSS-3 is 75lbs) will be done using a 230W UHP lamp over driven to 260W, ~15,000 lumens on 1mm arc :eek:
Combine that with a 9.5 inch precision 4th degree parabola quartz coated aluminum searchlight reflector (Reflector alone will cost about $700), will be my brightest short arc ever & likely to be the swan song of my short arc mods...
I think i'd not pay 425 bucks for a 250W 5mm arc with a 4.5" reflector. :D It has a 7" reflector, front 8.5 bezel and 6.75" body shell. Hopefully it would do 2-2.5km.
Someone needs to DIY the 575W 9" lightpipe version (you?), it has 7mm arc and 47000 lumens = 6.7k lumens /mm. Not sure how accurate is that though. But the aliexpress site also lists their 250W versions as 16000 and 18000 lumens respectively.
But this is the HMI 2500W bulb which theatres follow spot uses. Bulb is 41usd. Inverter and ballast are killers though. Likely the same ones used in the Skyrose/Skytrackers advertisement spots.
240000 / 8mm = 30k lumens /mm. Spot anything wrong? I am not sure.
If you don't mind i'll post some info here :
You seem to be on a roll for short-arcs. :D There used to be another nice member here years ago when i was just lurking, think its CarbonArc, together with BVH. But don't see him around nowadays.
ma_sha1
CT, USA
I am glad it's 7" reflector! I did a Mozo Mega HID with 7" reflector (POB clone), upgraded to 75W.
at ~8000 lumens on 4 mm arc (Philips 35W HID bulb over-driven). That's 2000lumens/mm, which it did 1.7 Million CPs.
Is the lightpipe bulb 5mm arc? 18,000 lumens on 5mm arc is 3500 lumens/mm, which will be 75% more surface brightness than my 75W Mozo/7" reflector. 1.7 million*175% = 3 Million CPs. 3 million cps at 18,000 lumens will be quite impressive indeed. But it won't out throw Mega Blaster or Moon Blaster.
You can see how bright the Moon Blaster illuminated the Fort Gorges at 0.9 mile :).
it can throw much further, It out throw the Helicoptor searchlight star burst SX-5,
which is a 500W Xenon short arc system with 7.5" diameter, 15 million cps.
http://www.spectrolab.com/DataSheets/SX5/ILS_SX-5.pdf
You are welcome to post lamp stats, I am numbers guy :). The 2500W lamp is insane! But I am not planning to do any huge power lights like that. My 260W UHP short arc will still be portable, I'll probably take it to a CPF shoot out at some point & it should be in the legendary 1000w xenon short arc Nightsun range (which cost >$30,000 dollars), the big brother of the start burst SX-5,
Plus, those huge sky tracker system advertising lights will be cheaper to buy one than to build one,
ebay sky tracker some times can be picked up for less than $1K. They are far from portable though.
BVH
CentCalCoast
Three times now, on initial loading, I get only 5 of the 7 pics. How strange. Upon hitting refresh, they all show up.
There's nothing like seeing high-power, long range beam shots! Thanks Ma for taking the time to do this.
ma_sha1
CT, USA
Thanks BVH,
I apologize for being so lazy about the long distance beam shots, they were promised several month ago when I build these lights, its long over due :eek:
Ra
The Netherlands
Great beam shots ma_sha !!
How about a get together at that pier sometime in the future, when your 'SwanBlaster' is finished..
Regards,
Ra.
Walterk
Netherlands
they were promised several month ago ..... its long over due
You made up for that good time!
Very nice shots and WOW it shows the beams really great.
The specs of the *hmptl*sound promising!
ma_sha1
CT, USA
Thanks Walterk!
Regards,
Ra.
Thanks Ra,
A get together of your Maxa Blaster with my "Swan" Blaster would be awesome indeed :) In fact, I would be interested in traveling to other states for a shoot out, I'd be even interested in traveling to the Netherlands for a shoot out, but I think traveling across border with the 20Ah battery pack might be an issue, besides the dual 400watt, 120V AC outlet, now it even has an extra piece sticking out that says 300V DC :eek:.
The look of the searchlight might cause trouble as well, as it's not the familiar spotlight look, which might raise some eyebrows, certainly not a sleeper.
If you manage to take the Maxa Blaster into US, I am motivated to go anywhere for a meet:)
Here is a sneak preview of the Swan Blaster work in progress :)
It has the 260W P-VIP ballast installed at the bottom(Gift from z_Ot10St who works at Osram)
, 230W/1.0 UHP lamp rear facing, with the 8" crappy peeling glass reflector from the vintage Cruise Hinds halogen searchlight host, it did 16 Million cps when measured at 100ft.
I'll be getting a 9.6" precision searchlight reflector & convert this to forward facing set-up,
with focus adjustment much like your Maxa Blaster set-up...
Yes it is 5mm arc from what I am told by the boss at Lightpipe. Actually the lumens is a bit on the low side at 72 Lm/W, compared to the other metal halides, some which you can see claim in the 100Lm/W region. But I know that stuff like Philips Mastercolour range (commercial ceramic metal halide) is 80Lm/W range....so i guess not too bad.
But anyway distant target beamshots are what really matters anyway. :)
Actually they are not that big : something like your 14" Schimdt Cassegrain telescopes.
http://www.youtube.com/watch?v=TlU9eZ-rZXI&feature=related
http://www.cloudynights.com/ubbthreads/attachments/1721846-DSC_0017.jpg
ma_sha1
CT, USA
making progress on my next short arc searchlight, I ordered the reflector from optiforms.com & received the official drawing of it. The reflector alone is 9.6" diameter and 7.5" deep, it'll pretty much take up the entire chamber of the searchlight host, leaving just about an inch of space behind the reflector, barely enough to mount the lamp & focus adjustment mechanism.
I decided to go with AQ (quartz over aluminum) coated version, after discussion with optiforms,
which costed about $150 more than Rhodium coated version but will give me extra 8% reflection.
BVH
CentCalCoast
I'm working with a quartz over alum reflector out of an ACR600 Marine 150 Watt short arc. It's the butterfly shape and it looks to be a very high quality reflector.
ma_sha1
CT, USA
Good to hear that, as I wasn't 100% sure about my choice, just that the extra 8% reflection is too tempting..
