alphamegapixels
Recently purchased a Surefire 3P body and was looking to purchase a drop in. Anyone have any suggestions? Thanks!
Malkoff M91 with a 16340 will give you about 500 lumens for 15 minutes. Not so practical but if you want a pocket rocket it's a blast. Also will run on cr123 for about 100 lumens with a decent run time.
Or,,,,,,😂😂😂That sounds fun, I'll need to try that with the VME and an E1.
Another vote for the M31W. It's so good.
Or,,,,,,😂😂😂
Yes, the 3P uses the C-series bezel, so a Malkoff of the right voltage would work (just be careful not to use a rechargeable 16340 with a Malkoff M31). The VME 2-piece bezel works on the E-series.The 3P uses the C-series head, rather than the VME - I think.
Looks like the best option is going Malkoff m31 and use a cr123.Yes, the 3P uses the C-series bezel, so a Malkoff of the right voltage would work (just be careful not to use a rechargeable 16340 with a Malkoff M31). The VME 2-piece bezel works on the E-series.
Personally not looking into Malkoff due to price range. But I do come across LFs often. LF does offer the single-cell (3-3.7V) D26 variant running at around 1.5A (previously 1.2A). They also have a tri-LED variant which yields very good area illumination IMO.Try Malkoff drop-in or Lumens Factory's.
Just one thing to note. Per LF, their modules have been tested and verified only on genuine SF hosts in stock form. So if you have clones, or legoed SF setups, any dimensional discrepancies could result in the failure of such modules due possible electrical contact issues. So be careful.I have an old 6P clone that I've upgraded several times over the years with Lumens Factory drop ins.
