Surefire 3P
kelmo
Sacramento
Hello fellow photon fiends!
I was visiting my cousin and he knows I like Surefire flashights and he literally came across a SF 3P! He found it on a walk. It has a little wear but has not been dropped. 8.5/10 condition with the original R30 lamp assembly (LA)! I will now be on the lookout for a R30 LA. I'll also be on the lookout for a N62 LA.
kelmo
Cool, if you want a cheap lumen fix you can get a 3.7v lamp from kai. com for about $4 . might be nice just to keep it stock, you still see 3v lamps on ebay....
Thanks for the info everybody!
I will keep it an incan. I forgot Lumens factory makes hotwires.
kelmo
More custom made 3P 18350 bodies are available and will run much longer and brighter than primary CR123A when using rechargeable 18350 cells.
BTW,
these will work for lamps which are designed for primaries such as P60 (2 cells), P90 (3 cells) and....
Rechargeable flashlight means more usage without hesitation.
