I'll be more direct.
How long will a M30 give me 200+ lumens with a 17670?
Will it be longer than what I can get from the M60 and two 3.7v RCR123's? How much longer?
From what I'm getting, the benefit of the M60 is it's ability to use 123's (and Li-Lion') but will not give full brightness as long as the M30.
I guess I thick skulled. This is all new to me. All I know is I have a 6P and I really like it
I just want it go give more light for a longer time without buying all those 123's.
I'm sorry for muddying the waters with the M60 single cell debate.:tinfoil:
All numbers are assuming using protected AW rechargeable cells.
M30 w 1x17670, ~240 lumens, 1h 20min. Abrupt shutoff.
No lithium primary backup except for a single 123 + spacer, ~170 lumens or so for an hour or so? Graceful decline with primaries.
A cheaper rechargeable configuration, purchasing 1 cell plus one backup. This single-cell configuration is more reliable.
M60 w 2xrcr123, ~240 lumens, 50min to 1 hr. Abrupt shutoff.
Good lithium primary backup, 2x123, 240 lumens ~ 1h 30 min. Graceful decline with primaries.
A more expensive rechargeable configuration, purchasing 2 cells plus two backups. This two cell configuration is theoretically less reliable.
For more fun,
(All I'm trying to show below is that the M30 is more efficient in the smaller hosts, but once you get to the larger hosts with capacities greater than 1x17670 (6P-sized) / 1x18650, the M30 is less useful as it cannot take more than a single lithium cell. The M60 starts offering considerably longer runtimes in the larger hosts.)
M30 w 1xrcr123 (same output, less runtime, but the best option for the very short 3P-type hosts)
M30 w 1x18500, 1x18650 (larger single-celled hosts), same output but considerably longer runtime.
M30 w 2xAA's (9P length host), ~130 lumens for 1h 30 min or so (depends upon alkaline or NiMH rechargeable)
M60 w 1x17670. Long runtime at less output, graceful decline.
M60 w 2x17500 (9P length host), ~240 lumens, 1:45-1:50
M60 w 2x18500 (FM-type host): ~240 lumens, 2h 15 min.
M60 w 2x18650, etc etc.
And we could also get into the L's and LL's for considerably increased runtimes at lower outputs as well. Great for backup lights.
For the 'Warm' Malkoff's released this year, runtime is comparable but output is ~30% less, so that gets confusing if you don't notice the 'W' in postings.
There are also the Malkoff P7's, the M60 MC-E's ... yes it's getting complicated again, my sincere apologies. Malkoff's were so much simpler last year before all of the new options.
Hope this helps,
