Surefire KL4 XP-G
DaFABRICATA
Michigan
I had an extra KL4 sitting around that wasn't getting used, SOOOOO...:devil:
A copper shim was made to fill the cavity from the old LUX V emitter and an XP-G on the 10mm board was installed. It seems to focus perfectly with the stock reflector and the uses the stock driver....for now. I have a few drivers on order and will likely replace the KL4 driver as I'm sure its a bit much for the XP-G.
The backside of the reflector area needs a little triming, but nothing major.
This thing is bright as hell!
Blows the doors off the original..:eek::D
Not nearly as floody and it throws pretty damn well
Beamshots below show a stock LUX V KL4, P7 KL4, & XP-G KL4...:naughty::twothumbs
Now to order more XP-G's:crazy:
LUX V---------------------P7------------------------XP-G
LUX V
P7
XP-G
DaFab, would you check the battery draw at the tailcap? Also, will it run on a 17670? If so current draw from battery?
Bill
Love the beamshot- really does out-do the Lux V. Is the spill much dimmer / smaller or just by comparison to the hotspot?
The spill reaches out the same but is brighter too!:party:
It finally got dark out. I tried it outside and what a difference!
It out-throws the Kl4 with a P7.
I will get some beamshot in the dark when I get a night when it isn't raining. Beamshots in the rain never look as impressive.:(
HAHA I already did mine.
I prefer keep original form factor. So I didn't touch the head and filed down a MCPCB.
I'm satisfied with beam quality.
I'll add some glowing epoxy or reflective sheet to cover the urgly face.
ROK, nice shots, and great beam. Do not worry about the "ugly face". Beauty is in the eye of the beholder; it does not bother me.
Bill
ROK,
NICE JOB!!!...Very clean!
It is a very nice beam and output isn't it?
YEAH! I love the beam quality and output.
In my study, XPG is compatible with Lux & SSC P4 than XR-E.
I think 2mm*20mm MCPCB with diagonal +/- pattern of pcb is the better for KL4 mod.
I have searched buck/boost convert for 1 cell & 2 cell use but no luck.
Anyone knows this kind of converter?
The SF KL1, buck/boost.
Bill
I'll let you borrow mine. And while I'm there you can help me solder some LEDs!
Mark,
Works for me!
Send me a PM if you want to get together to do some modding!:thumbsup:
Soldering with this new Hakko is sooo nice..:naughty:
Hello, thanks for the nice mod, i'm a newbie in soldering, which hakko do you use?
Good soldering iron is helpful but not requisite.
I have used cheap HAKKO 980 with fine tip. Most important factor is experience.
Another mod with XP-G
Nice one!!
Ya beat me to it..:laughing:
BEAMSHOT PLEASE!!
How does it do in the KT1/KT2/KT4?:popcorn:
BTW...I use a Hakko 936:twothumbs
Looks like you filed down a 10mm round. I have some 8mm rounds on order (but not in stock right now) to avoid that hassle. I also have some 10mm rounds on order if I can't wait that long for the 8mm.
What focus height is your tower? Seoul? Lux? What's your driver?
Can you measure the total height of the XP-G package from bottom of the MCPCB to the top of the square ceramic substrate. I would assume that it is close to 2mm + 0.58mm. Does it look like the XP-G die sits at the same level as the top of the ceramic substrate? I'm trying to estimate the XP-G die height to see how close it is to a Seoul focus.
My plan is to mount the XP-G on a Seoul focus tower, driving it with an SOB1185 (that's what I happen to have in my parts drawer, would have preferred an SOB1000). I plan to test the XP-G tower in an SRTH, T-62, KT1/2, and KT4 and compare it to P4 and MC-E towers.
