Sorry, I was very busy lately. Yes, this is a mod, I did it myself. Each LED has an individual SMD resistor and once you've opened the light, replacing the LEDs is not very hard. I got five sets of replacement LEDs for testing which ones I like, all of them being high-flux 3mm LEDs: amber, white, warm white, UV and yellow. I liked amber and UV best and was only willing to give up the green and blue LEDs, red and IR I wanted to keep. White was very tempting, but since I already have many lights with multiple white LEDs, I went for UV instead, and the Kroma Milspec has low output white from the main LED, so UV was more of an addition.
I did open the light because the selector ring failed and I didn't like the ringy blue beam anyway. One thing I can tell you: in military use, the selector ring of each and every Kroma Milspec will sooner or later fail, that's for sure. Surefire knows what military equipment has to endure, look at the M2 for example, that's a light that will hold up in the real world of military use! The little piece of plastic that provides the stops in the selector ring of the Kroma Milspec? It's a joke you would expect in a cheap toy. My advice: treat the selector ring of your Kroma Milspec with care.
