watchcollector1968
- Joined
- Mar 29, 2008
- Messages
- 67
Disclaimer: I am no reviewer and dont have all the tech knowledge so many here have. I have fun with my lights and carry one each day.
Ok, the light is 5.1" long, runs on 2x123 batteries. It has 3 modes which are accessed by pushing the button, letting it go and pushing again within 2 second to cycle through each one. Nice and easy to do. It has momentary and constant on capabilities.
One thing I like and others may not is that it comes on in low mode first (5 lumens for 75 hours)...medium (50 for 15 hours) and then high (160 for 2 hours).
Low is excellent for a dark house or just enough light outside for walking when you only need short range light.
Medium is a great all purpose outdoor light. With the throw and spill this light produces this mode should serve most needs.
High is a lot of fun for seeing how much you can light something up and impressing people when compared to there larger MagLites. For practical purposes I dont see a lot of advantage of the much higher output and shorter runtime. The medium is more than bright enough and has a far longer runtime.
The body of the light has a couple of flat surfaces (where all the writing is) and finger grooves. It gives a nice secure grip, although the feel takes a bit of getting used to. I would think that with slick hands the older style knurling might be better...that is just speculation on my part.
The bezel has some interesting "teeth". Im not sure if there is a reason these are there. They are not as aggressive as say the E2D strike bezel, not even close. Not saying they would not make an effective impact device if it came to that, I would not want to be hit with it although that pretty much applies to any flashlight. Cosmetically the teeth look a little strange at first, but they grow on you.
Surefire certainly likes to let you know you are carrying a Surefire...lots of writing on this light...makes you feel like you are holding a billboard. It does not look bad at all, makes a nice contrast to a black flashlight...they might have overdone it just a hair though.
The reflector is a little different...domed (right term?) and a flat area surrounding the LED...This might be why the combination of flood and throw is so good.
Im not very good at beamshots apparently. All were done on high, f5 and 2 second shutter...distance from light to target is about 50 feet.
This is the Stratum on high.
The second is a Fenix TK40-R2 on high at 240 Lumens.
The last is the Surefire BackUp on high, 80 Lumens.
Not sure how true these photos represent the difference in beams, but hopefully gives you some idea. The photos also dont show the spill that any of the lights produce...that is due to my lack of beamshot know how and something I am going to work on.
All beam shots were done with each light having a fresh set of Surefire batteries.
Hope this is at least a little informative...thanks for reading.
