WarriorOfLight
Before you try to bore it you should check if the 18650 cell will fit in the "outer threads" of the UM2 head. I'm not 100% sure, but I might checked this and found out this outer threads are not wide enough for a 18650 cell.So far I am very impressed although I've had it all of an hour. I'll try to take some pictures whenever I get a sunny day outside comparing the two side by side. I hope to mail it off in a couple of weeks to get it bored out to accept an 18650 but I don't know if I'm ready to let it go just yet.
The outer thread of a U2 is if I remember correctly wider than the UM2 outer threads. Both battery tubes are also not compatible. You can not put on the U2 body the UM2 head.
The Surefire Holster V91 also fits perfectly. This holster fits for Kroma / U2 and UM2. The Diffuser / Filter / Beamcover is the 1.47 Inch version FM6xOh another thing I should mention is that the Surefire diffuser I use for my U2 (not sure of the part number off hand) fits the UM2 perfectly!
