HKJ
[size=+3]Ampsplus 18350 NMC 1150mAh (Black) 2020[/size]
Official specifications:
A high current and high capacity 18350 battery from Ampsplus.
The two cell match nicely and can deliver about 10A before they have problems.
[size=+3]Conclusion[/size]
This cell is from the fairly new generation of 18350 cells that can deliver a lot of current and have lot of capacity (for the size).
It is is good battery.
[size=+3]Notes and links[/size]
The batteries was supplied by Ampsplus for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
- Battery Size: 18.30mm x 35.00mm
- Nominal Voltage: 3.70V
- Nominal Capacity: 1200mAh
- Min rated Capacity: 1150mAh
- Charging Method: CC/CV 4.20V
- Discharge Voltage: 2.00V (Average Cut Off)
- Charging Current CC: 500mA
- Rapid Charging Current: 1000mA max.
- Continuous Discharge Current: 10A
- Max. Short Discharge Current: 15A
- Weight: 25 gr . max
- Colour: Black , Red , Silver
- Version: Flat Top
- Protection Circuit Board / PCB: No / Unprotected
- Type: Rechargeable , NMC , IMR , INR , High Drain
