Test/review of Hohm Tech School2
HKJ
Copenhagen, Denmark
[size=+3]Hohm Tech School2[/size]
A two slot LiIon only charger from Hohm Tech that is USB powered.
The charger was in a cardboard box with specifications on it.
The box included the charger, a USB cable and a instruction sheet.
The USB cable is very thick.
The charger has a USB micro input.
There are no buttons, only a led for each slot. The leds is red while charging and green when the battery is full.
There is two current settings on the charger and they are selected by the battery length. There is a nice marking showing at what point the current changes.
The charger has specifications on the back.
The connection are the common slider style that can handle from 32mm to 76mm, this means all batteries will fit.
The current for 10440 is a bit on the high side.
[size=+2]Measurements charger[/size]
  • When not powered it will discharge a LiIon battery with about than 0.22mA
  • When powered the charge will charge with less than 1mA when finished.
  • Below 0.5V the battery is assumed to defect and the red indicator blinks.
  • Between 0.5V and 2.8V the charger will use reduced charge current
  • Above 2.8V the charger will use full current.
  • Charger will restart if battery voltage drops below 3.9V.
  • Current changes around 60mm battery length as marked on the charger.
  • Power consumption when idle without batteries is 6.1mA from USB
The charger uses a sort of CC/CV charging, but the current drops in fairly large steps. This is not a problem for the battery, but will mean slightly longer charger time.The charge time is not that long, because the charger maintain full current up to about full battery voltage, before it is reduced. Termination current is around 160mA, this is a slight high for some batteries.
Second slot is similar, but the final voltage is slightly different.
These two batteries are similar.
The regulation has some problems with this cell, but the end result is good enough.
The smaller battery means lower charge current.
Simulating a weak charger or long cable with a 0.5ohm resistor do not prevent the charger from charging the cell, but the termination is not that good.
With two cells at 1A it cannot maintain full current as long, this means slightly longer charge time, but the end result is fine.
M1: 40.6°C, M2: 41.1°C, M3: 44.8°C, HS1: 53.3°C
M1: 57.0°C, M2: 45.4°C
The charger needs about 8 seconds to reach full current.
The charger will discharge a full LiIon battery with about 0.22mA.
The charge profile. The drop in charge current is probably heat related, the charger use a linear regulator and when the LiIon battery is at low voltage the regulator will get hotter.
The charger will not work with a unstable voltage.
[size=+2]Conclusion[/size]
It is a simple and easy to use LiIon charger that does what it is supposed to do.
I will rate it as fairly good.
[size=+3]Notes[/size]
The charger was supplied by a Hohm for review.
Here is an explanation on how I did the above charge curves: How do I test a charger
Could you please explain the "solar panel powering"?
I slowly reduces the voltage a bit, then turn it up again, to sort of simulate a shadow passing a solar panel. The voltage markings is how much I reduce the voltage. I do that a lot of times to see if the charger recovers when the shadow goes away, i.e. the voltage goes up again. If it stops charging for some voltage there is a risk a passing shadow will stop the charger. Some microprocessors has circuit that that can be enabled and would eliminate this problem completely.
All this is only relevant when connecting directly to a solar panel, if there is any short of battery between to maintain the voltage, like there typically is with 12V panels, this is irrelevant.
Here is the measurement shown with a time scale, you can see the input voltage drops, recovers and drops again (A little bit more) a lot of time. I believe this chart is way to messy to look at, that is the reason I made the representation that is shown in the review.
OK thanks.
You mean on the charger's input?
I thought that is USB? I'd have thought a properly regulated voltage would be assumed in that case.
But then I've never imagined using a solar panel without a good quality solar controller,
and I've never seen one of those with a USB output port.
OK thanks.
The 5V USB panels are a (typical foldable) solar panel, a voltage regulator and a USB connector. They will deliver 5V when there is enough sun, but have no storage capacity and the output voltage will drop more or less when there is a shadow on the panel.
They are probably most useful if you are camping away from any power.
Interesting, but not something I'd use.
IMO a SC should stop outputting or maybe shut down when panel voltage drops so low that output setpoint can't be reached.
Thanks for explaining
