Test/review of Samsung INR18650-35E 3500mAh (Pink) 3
HKJ
Copenhagen, Denmark
[size=+3]Samsung INR18650-35E 3500mAh (Pink) 3[/size]
Official specifications:
  • Nominal capacity: 3500mAh
  • Minimum capacity: 3350mAh
  • Nominal voltage: 3,6V - 3,7V
  • Charging voltage: 4,2V
  • Discharge current: 8A
  • Maximum discharge current: 13A
  • Charge current: 0,6C 2000mA
  • Discharge end voltage: 2,65V
  • Pluspol: FlatTop
  • Chemistry: LiNiCoAlO2
  • Diameter: 18,55mm ± 0,1
  • Height: 65,25mm ± 0,15
  • Weight: 48g ± 1
This is a new 35E cell (Supposed to be 2021) from Samsung where there the cell includes a warning. It is a high capacity cell.
The two cells tracks fairly well, the cell can handle the rated 8A.
[size=+3]Conclusion[/size]
This is a good cell, performance is better than the 2020 cell I tested and better at high current than first 35E cell I tested.
[size=+3]Notes and links[/size]
The batteries was supplied by reader for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
