Test/review of Vapcell INR14500 L10 1050mAh (Purple) 2020
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR14500 L10 1050mAh (Purple) 2020[/size]
Official specifications:
  • Model: INR14500 L10
  • Size: 14.0*49.0mm
  • Type: Flat top
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 1050mAh (0.2C discharge)
  • Min capacity: 1000mAh (0.2C discharge)
  • Weight: Max: 22g
  • Internal resistance: Max:66mOhm (AC 1kHz)
  • Standard Charge: 500mA,CCCV 50mA cut-off
  • Quick Charge Current: 1000mA
  • Max Continuous Discharge Current: 3A
  • Operating Temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~75°C
  • Storage Temperature: -5°C~35°C
  • Storage Humidity: <75%RH
This is a high capacity 14500 LiIon cell frm Vapcell.
The two cells match nicely and the cell has lots of capacity for a 14500 cell, but the cell is not for high current.
Discharge-Vapcell%20INR14500%20L10%201050mAh%20%28Purple%29%202020-pulse-0.5%2010%2010-IR.png
[size=+3]Conclusion[/size]
This is the highest capacity 14500 cell I have tested to data (Spring 2020), but it is for moderate current draw (Preferable not more than 1-2A), not for high current.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Glad to see a well performing 14500 size as I like the form factor for EDC. Enough juice to get you out of a jam, yet small enough to hold in your mouth if both hands are needed for say car repairs.
Sent from my Pixel 2 using Tapatalk
