HKJ
[size=+3]Vapcell INR18650 3000mAh H30 (Red) 2019[/size]
Official specifications:
This is a fairly high capacity and fairly high capacity cell in the usual 18650 size.
The cells matches nicely and can deliver 15A continuous, but at 20A they got too hot.
I forgot the temperature sensor on one of the batteries.
[size=+3]Conclusion[/size]
The cell has good capacity at high current.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Model: INR18650 3000mah 20A
- Size: 18.3*64.9mm
- Nominal voltage: 3.60V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.5V
- Typical Capacity: 3000mAh (0.2C discharge)
- Min capacity: 2900mAh (0.2C discharge)
- Weight: Max:48g
- Internal resistance: Max:15mOhm AC 1kHz
- Standard Charge: 1500mA,CCCV 100mA cut-off
- Charging Time: 3.0hours(standard charge)
- Quick Charge Current:4000mA
- Max Continuous Discharge Current: 20000mA
