HKJ
[size=+3]Vapcell INR18650 3000mAh P1830A (Black-green) 2020[/size]
Official specifications:
This is a protected 3000mAh 18650 battery that can deliver a fair amount of current.
The two cells match nicely.
I stopped this discharge due to temperature.
[size=+3]Conclusion[/size]
The batteries looks fine.
The over current protection will not protect against a the battery getting too warm, only against gross overloads (This is fairly common).
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Size: 18.4*69.5mm
- Nominal voltage: 3.60V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.50V
- Typical Capacity: 3000mAh (0.2C discharge)
- Min capacity: 2950mAh (0.2C discharge)
- Weight: Max:50g
- Internal resistance: Max:23mOhm (AC 1kHz)
- Standard Charge: 1500mA,CCCV 100mA cut-off
- Quick Charge Current: 4000mA
- Max Continuous Discharge Current: 15000mA (15A)
- Operating Temperature: Charging, 0°C ~ 45°C
- Operating Temperature: Discharging, -20°C ~ 70°C
- Storage Temperature: -5°C ~ 35°C
- Over charge protection voltage: 4.25+0.05/-0V
- Over discharge protection voltage: 2.50+0/-0.05V
- Over current protection current: 17A ~ 20A
