Test/review of Vapcell INR26650 5000mAh (Purple) 2020
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR26650 5000mAh (Purple) 2020[/size]
Official specifications:
  • Model:INR26650 5000mah 20A
  • Size: 26.1*65.5mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Weight: Max:95g
  • Internal resistance: Max:15mOhm AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 20A
This is a 26650 LiIon battery with fairly good capacity and current capability.
The two cells match nicely and do easily have the rated capacity. As usual I try a bit above rated current, on this battery it was not a good idea. It has some sort of fuse (Probably temperature based) that blows when continuous overloaded, it is good good safety, but I could not finish my test on the first battery. For the second I reduced maximum test current.
Discharge-Vapcell%20INR26650%205000mAh%20%28Purple%29%202020-pulse-1.0%2010%2010-IR.png
[size=+3]Conclusion[/size]
It is a good battery that can deliver a lot of current and capacity and it has protection against getting too hot.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
